Home > Td5 > Noisy wiper motor
lightning
Noisy wiper motor
The wiper motor on my Defender TD5 makes a clicking noise at the end of the travel, as the blades reverse their direction. Is there anything l can do with it or do l need a new motor? I replaced the rack and wheel boxes a couple of years ago with genuine LR parts and they are still fine.
Post #746525 19th Dec 2018 11:08pm
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
Hi lightning,
Sorry I can't help however I have the same issue with mine so keen to see if/ how anybody has resolved it.
Post #746530 19th Dec 2018 11:17pm
The click will be wear at some point in the drive mechanism. If you have recently replaced the rack and wheelboxes (and used good quality replacements) the most likely source will be the gear and crank mechanism in the motor. I believe that these are available as a separate parts though.
It is entirely normal for the prehistoric linkage on the Defender to do this, there are so many individual wear points that it is easy to understand why every other manufacturer changed to rod drive 40 years ago!
You can check for wear in the wheelboxes and drive rack by seeing how much relative movement there is between the two wiper arms (hold one and waggle the other), and to a lesser extent in the motor crank by waggling both wipers together.
Apart from being an irritant, a click/clunk from the crank is generally not harmful and the motor will run for years like this.
Post #746571 20th Dec 2018 10:08am
lightning
Thank you for the information
I will take a look at it next time l have to remove the dash, which will be to fit the cruise control kit.
Post #747283 25th Dec 2018 11:50am
