Home > Puma (Tdci) > Replaced injector seals
Page 2 of 2 <12
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Before changing the injector I would try to do the learning process !!!!
Post #726245 30th Aug 2018 10:58am
Yeti110
Sweden
Hi,
I understood it had to be done in-situ. Can it be programmed on a bench, in that case?
I've heard this from both a Ford dealership and a Bosch Diesel specialist.
Post #726247 30th Aug 2018 11:17am
Fernando
No, only with the engine running and at temperature.
With Nanocom or similar
Post #726256 30th Aug 2018 12:01pm
Yeti110
Sweden
Good, because I've arranged for that to happen tomorrow.
With any luck I'll be back driving (without smoke) in the afternoon. BTW, it looks like the injector was the cause of black smoke, by over fueling. The copper seals were all fine.
On the bright side, they're done now and I found the cause of the problem anyway.
Thanks again.
Post #726260 30th Aug 2018 12:24pm
dgardel
Italy
pay attention, a leaking injector(s) can produce a big hole on the piston(s)!!!!
and new injectors MUST BE re-coded into the ECU!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #726397 31st Aug 2018 9:05am
Yeti110
Sweden
I thought I would update this post.
It turned out all four injectors (that were in the car when I bought it) were shot. Not one of them made it to the second phase of the check test. They were also not coded to the ECU. I had driven across Europe, unaware of this.
Anyway, it turned out that the leaking injectors had been the cause of my P0234 over-boost issue, which was also causing me a headache at the time.
Land Rover whilst very nice, after a diagnostics test, had assured me it was a failed turbo. Luckily, I decided to think before i spent big money on a new turbocharger. Completely separately to the turbo problem, I decided to change the injector seals which led me to the failed injectors and ultimately to finding the solution.
Anyway, I'm happy now and after a few months the car is still running great.
Post #746315 18th Dec 2018 5:49pm
williamthedog
Glad to hear that you got it sorted Thumbs Up
Post #746341 18th Dec 2018 8:52pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Good news Thumbs Up
Post #746360 18th Dec 2018 10:52pm
Yeti110
Sweden
Thank you.
P0234 can be triggered by leaking injectors!
Post #746425 19th Dec 2018 3:30pm
Page 2 of 2 <12
