Home > Technical > 200tdi Disco 1 suddenly stopped
dioliahary
Ran about a mile this morning then just cut out all electriics good, 12v to pump, diesel at injectors but more like a weep than a squirt when nut cracked. So I think a fuel problem. Recently renewed timing belt but has done aroun 100 miles since renewal.
The mechanical pump does not seem to have much resistance when operating, if this was faulty could it cause low fuel pressure? 1990 200tdi conversion 90
Post #746065 16th Dec 2018 9:27pm
Retroanaconda
Remove the oil filler cap then crank the engine and watch to see if the rocker arms move just to rule out the belt what with that being the last thing you changed.
Post #746069 16th Dec 2018 9:38pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
You might find answers from watching this:
Post #746212 17th Dec 2018 10:14pm
landy andy
Stop solenoid?
Weak pump?
Post #746232 18th Dec 2018 12:01am
dioliahary
I have taken the stop solenoid plunger out, cracked pipe at fuel filter outlet and got fuel flow when cranking the engine, rockers are operating so no timing belt failure therefore none of these are faulty. I am gettig fuel at the injector inlet pipe but not sure how it should flow, so I have disconnected the metal injector pipe at the injector, cranked the engine and I get a squirt of fuel from the pipe just not sure if it should be more aggresive therefore lack of pressure. 1990 200tdi conversion 90
Post #746238 18th Dec 2018 12:17am
donmacn
Maybe not 100% what you're after, but I happened to watch this video last night, and there's a bit where he fits a new lift pump, and has diesel spraying out of the filter bleed screw. This might give you an idea of the sort of flow that's normal/needed.
https://m.youtube.com/watch?v=
Maybe not so much use if the engine isn't running though.... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #746275 18th Dec 2018 10:38am
bigfatsi
United Kingdom 2003 Defender 110 Td5 CSW Aintree Green
Ah I remember having those days.
9/10 it's the lift pump. I have had leaking fuel pipe joints and even a holed pick up pipe before though. And a dodgy fuel filter connection.
Can you try the old fuel can on the roof trick for diagnostic? Or a clear pipe in line to check for air?
S
Post #746284 18th Dec 2018 12:38pm
dioliahary
Injectors don’t look too clever?
Post #746356 18th Dec 2018 10:32pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
What the heck happened to those injectors?
Post #746374 19th Dec 2018 2:59am
dioliahary
Getting them tested today, not sure why they are like this though 1990 200tdi conversion 90
Post #746407 19th Dec 2018 12:49pm
dioliahary
Hmmm injectors tested like new, running out of ideas now, guess check timing next but do not understand how the timing belt could slip if that’s the problem. 1990 200tdi conversion 90
Post #746434 19th Dec 2018 4:30pm
Bps
change fuel filter and swop lift pump
Post #746449 19th Dec 2018 5:56pm
dioliahary
I changed the fuel filter and I inspected the old one, it was in excellent condition. I am about to check timing, removing crankcase case.
But before I do can anyone tell me if a faulty or inefficient lift pump would cause this situation? 1990 200tdi conversion 90
Post #746458 19th Dec 2018 6:34pm
donmacn
I'm afraid I can't be definitive, just because I can't remember the details.
I remember having poor running, or starting issues which were eventually traced to the lift pump. The symptoms weren't as bad as yours seems to be, but perhaps it was summer and the fuel was thinner/lighter?
I think the 'main' pump will draw fuel through, even if the lift pump isn't working but everything else would need to be in good order.
Sorry - not much help. On the plus side, it's not an expensive part.... Donald
in the past..
Post #746494 19th Dec 2018 8:43pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
The engine will pull well enough without the lift pump as the injection pump will pull fuel through. If knackered though, you will notice the difference when you replace it.
HTH
Post #746516 19th Dec 2018 10:36pm
