![]() | Home > Puma (Tdci) > Was BBus standard? |
2.4 or 2.2 engine
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 ![]() ![]() ![]() |
Sounds like a similar situation to myself - should have checked before I ordered!
Mine is a 2009 XS station wagon and I can't find it, so i'm guessing it wasn't a standard option? |
Not all 07 to 2011 Puma TDCi defender have wire and plug in place in the wing loom
![]() Click image to enlarge check C1264 plug if you only have one black wire concreted in the plug you will not have the brown BBUS plug at head light end. If you have 4 black wire concreted in the plug you will brown BBUS plug at head light end. all is not lost if your loom is missing wiring and brown plug ![]() Click image to enlarge ![]() Click image to enlarge |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
BBUS was only standard from MY 11 onwards
It's not behind either headlight on my 2013 model. I know it has one fitted as I've inadvertently set it off, but I'm dammed if I can find it (which is a good thing).
Perhaps LR installed them differently on later vehicles? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 ![]() |
late 2008 2.4 |
late 2008 2.4 ok
Thanks for this, i’ll take a look tomorrow. Its always possible the previous owner relocated it already.... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Td5s have the harness with the plug. If your TDCi doesn't, you can pick up a Td5 harness from a breaker.
or just add wiring and plug
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Never fitted on export models. My 2015 doesn't even have an alarm. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 ![]() ![]() ![]() |
WindyJ, I did the exact same when I bought a BBUS relocation loom!
![]() Took a bit of mining to find the relevant info as naturally most folk aren't too keen to share security system info. |
