![]() | Home > Maintenance & Modifications > Turbo Manifold Gasket Leak - Puma TDCI |
| SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464
Hello,
My Defender 90 has every now and then an exhaust leak from the turbo manifold and I have replaced it several times with Nakatanenga gasket, I've retightened it now and it still whistles slightly. What would you recommend I do? I am on my second gasket now and I predominately use my Defender 90 as my daily driver. Thank you in advance 2016 Defender 90 Adventure Edition |
Thank you,
The turbo manifold is fine as it looks. 2016 Defender 90 Adventure Edition |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
No personal experience on this engine but on others
Both surfaces need to be clean, flat or slightly convex, needs to be reassembled with everything cold, the exhaust system needs to be under no bias when fitted, do up the nuts loosely and tighten up a bit at a time, until all of them are at the correct torque. After you have run it upto temperature and it has cooled down re torque the nuts. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
This may be of some interest
https://www.defender2.net/forum/topic457.html?highlight=turbo 130's have feeling's as well you know |
Thank you for your insight, I will give it another try. 2016 Defender 90 Adventure Edition
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
It is reasonably common for the manifold-to-head gasket to do the same thing, so it might be worth checking that joint too.
Thank you I will look into that as well. 2016 Defender 90 Adventure Edition
| All times are GMT |
