Home > Puma (Tdci) > Self inflicted electrical problem
Page 4 of 4 <1234
dorsetsmith
had Idea to day ignition switched 12V to the alarm missing see Paul Brown beat me to it Thumbs Up
Pin 10 ignition switched 12V - which is not working – I get absolutely nothing when I turn the key.
white/ green wire from pin 10 up to Connector header Co285 Yellow location behind centre of the dash and down to fuse 8 this fuse and fuse 15 fed from ignition switch white wire 4 mm connector Coo94R
Post #745052 10th Dec 2018 9:46pm
Martin
Site Admin
10AS pin 10 is fed from Fuse 8 on the dash fusebox.
With your meter try your voltage check on both sides of the top of Fuse 8 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #745054 10th Dec 2018 9:46pm
redline
Switzerland
Fixed!! Very Happy
Turns out fuse 8 was blown as well! I'm sure I had checked this at the beginning - the fuse actually looks ok visually, but when tested it was clearly gone. Lesson learned - be thorough when checking things Rolling Eyes
Many, many thanks for the help Martin and Dorset - would have been a nightmare without your guidance. A bit curious though how you could know that pin 10 is fed by fuse 8, etc...?! The wiring diagrams are diabolical, and hard to trace issues across functional circuits. Dorset - where is that connector wiring info from?
The benefit of this little exercise is that having seen the mess of wires behind the dashboard I've decided that at some point it will come off, in order to:
1. Tidy things up, label the main harnesses, and strip out any unused wires - such as the one below that is just hanging there... no idea what it does / did.
2. Relocate the 10AS. I'll speak to Paul at TechnoZen about the possibility of a harness extension, to move the unit somewhere more accessible.
3. Redo some spliced / taped connections with proper crimped connectors. Not sure if this is the work of LR, dealers, or previous owners... Example below, but there seem to be quite a few around fuse box and dashboard area.
Any idea what this is?
Why, why, why? Mad
Post #745115 11th Dec 2018 10:14am
dorsetsmith
1. For top pic wire colour Question
see below link to connector wiring info 2007
https://1drv.ms/b/s!AtZSoWFHDgnGjECIf_wOfqrjegKe
Post #745117 11th Dec 2018 10:18am
redline
Switzerland
Dorset - both are black/white striped
Post #745120 11th Dec 2018 10:21am
dorsetsmith
L/h front tweeter wire & connector
Post #745122 11th Dec 2018 10:33am
dorsetsmith
Why, why, why? is part of the horn wiring Rolling Eyes
Post #745133 11th Dec 2018 11:32am
redline
Switzerland
Dorset - thanks for that! Makes sense that its the tweeter wire - they were replaced, and have their own driver box. Would have thought they'd taken the old wiring out though Mad
Horn wiring - was questioning the splicing. Wonder why they did that, and if you have to cut and join a wire, at least use a crimped connector. Its an example of one of the many wiring issues I need to tidy up Rolling Eyes
Post #745151 11th Dec 2018 2:02pm
dorsetsmith
Would have thought they'd taken the old wiring out though that wiring all part of the dash loom big job to remove it
Post #745166 11th Dec 2018 3:07pm
Page 4 of 4 <1234
