Home > Maintenance & Modifications > Suspension lift - am I missing the point?! |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
Higher ground clearance from main chassis as more movement between top of wheel and bottom of arch.
Obviously still leaves difs and axels at same height, only way you can get round that is portal axels or larger tyres. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
10th Dec 2018 8:47am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
As Osloblue said, raised suspension increases the ramp angles/clearance from chassis/bumpers to ground.
It also increases the articulation of the axles (the wheel travel from top to bottom, independant from each other). This improves the ability to cross irregular terrain whilst keeping all four wheels in contact with the surface. Loss of contact means loss of stability, risk of sliding on a slope, and most important, loss of drive. To access the advantages of raised suspension off road, the anti roll bars need to be removed or disconnected. Although the standard Defender lockable centre diff goes some way to keep things moving when one wheel (and therefore one axle) loses drive, it still limits the ability of the vehicle. The first step is to improve the articulation. The disadvantages of raised supension (particularly combined with the absense of arb´s) are many. Larger frontal area (even worse than standard aerodynamics), increased body roll and less controllable on-road handling, access to low entrances ....and short chics have more difficulty climbing abord. Thankfully it is all up to personal taste and need, and is all reversible or easily modified. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
10th Dec 2018 9:59am |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 389 |
Better approach and departure angles so less likely to get hung up entering or leaving ditches
Better ramp breakover angle / clearance so less likely to ground out cresting a hump (or exiting the aforementioned ditch) Tyre clearance for wide tyres Looks (!) Curious affinity for replicating the door-handle scraping on corners that is characteristic of older vehicles --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
10th Dec 2018 10:00am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
With heavy duty or lifted suspension it will also give same sort of articulation as standard when vehicle is laden for say overlanding.
Our red 110 has heavy duty suspension and the rear ARB broke many years ago. You learn to drive within the limitations of the vehicle. Brendan |
10th Dec 2018 10:33am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2875 |
Also very unstable at higher speeds
10th Dec 2018 11:38am |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 |
Many thanks for the feedback all - greatly appreciated.
Mark |
10th Dec 2018 2:50pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Some good answers there... Does make sense now..
I was wondering the same thing... Thanks. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
10th Dec 2018 2:58pm |
Is there a 'sensible way of getting a bit more lift without having to worry about how it will affect the 'on road' behavior? I run 255/85/16 KM2's and deep ruts cause rubbing on the arches/bottoming out.
Thanks Mark |
15th Jan 2019 5:32pm |
Mark air bag suspension, to changed height as needed.
Or if your man enough ( and have the money) portal axles. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
15th Jan 2019 6:41pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
A lift gives you articulation.
Click image to enlarge And so more off road traction and stability. |
15th Jan 2019 6:53pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1778 |
Like the wheels
Sorry, Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
15th Jan 2019 6:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
What rims are you using? I run tha same tyres on Blindos and they don't rub! |
15th Jan 2019 7:27pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
Heavy duty military spec springs |
15th Jan 2019 8:23pm |
Hi. I have the standard Boost alloys fitted. Many thanks Mark |
16th Jan 2019 7:54am |
