Home > Td5 > Defender drag link adjustment
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Fitted a new heavy duty drag link bar and ball joint, marked and measured the old one as best I could. The steering wheel is almost straight, some minor adjustment should correct this. But it now slightly pulls to the right when braking and the steering wheel pulls aswell?
Any ideas?
Post #744654 8th Dec 2018 12:42pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check tire pressures first before gouhg any further. Strangely enough low on one side may well cause that. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #744702 8th Dec 2018 6:59pm
Did you just change the drag link, or did you change the trackrod as well?
Post #744715 8th Dec 2018 7:37pm
jst
As above, sounds like tracking, did you change rear bar too? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #744740 8th Dec 2018 10:49pm
