Home > Td5 > TD5 heater not working |
fuse 13 (20 amp) ok in the passenger fuse box
Have you voltage at fuse 13 Toggle to engage the heater on the left hand side of the dash, this in side your dash Click image to enlarge (red arrow ) black ground wire make shore connected If the fuse has blow check fan blade and motor will mover and not seized |
7th Dec 2018 1:41pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
What Dorsetsmith said about covers it all. It is truly a very simple system and super easy to trace problems. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
7th Dec 2018 6:44pm |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
Brilliant, thank you!
I will let you know how I get on, cheers Instagram - @Land_Rover_Defender |
8th Dec 2018 12:35am |
