Home > Puma (Tdci) > Coolant temperature issue and limp mode (revisited)
Page 2 of 2 <12
Eduardo
Well,
Finally the new Allisport radiator arrived today and will be installed next week.
Some questions here:
Shall I do a chemical washing of the cooling system to improve the heat transference?
Any advice on this point?
Anyone has used Ceratec from Liquimoly?
Cheers to all thanks for all the advices! Eduardo
Post #744490 7th Dec 2018 3:18pm
MK
I would not do it unless I see any signs of scale, deposits, corrosion.
I use redish motul Inugel and works well. Any fit for purpose coolant will do well (I would not use supermarket stuff).
I use ceratec but only 1 can. Not sure if makes any difference. Too much of "something" isnt good (Bo in this case). Puma 110" SW
Post #744518 7th Dec 2018 6:10pm
MK
Eduardo
Have you thought on extending by 2 inches the lower half fan shroud? I was just looking at it and there is some room to do it. Of course not sure if it works but several engines have a complete shroud all around.
Slds Puma 110" SW
Post #745234 11th Dec 2018 9:30pm
Eduardo
Already done using the nakatenga extender.
The difference is just 2-5°C less, but do not provide the final solution.
Cheers Eduardo
Post #745291 12th Dec 2018 1:09pm
MK
Alright. I mean the plastic tunnel-shapped thing around the fan Puma 110" SW
Post #745292 12th Dec 2018 1:36pm
Eduardo
Ahhh...
Anyway the effect should be the same (put the fan more inside the cover)
Cheers! Eduardo
Post #745494 13th Dec 2018 1:29pm
dgardel
Italy
Eduardo
did you install the "original" thermostat or the "cooler" one?
Exists 3 types of thermostat configurations:
- PEM100990 88°C - 96°C HARD SPRING
- PEL500110 82°C - 89°C SOFT SPRING
- PEM101020 82°C - 89°C HARD SPRING
I installed the PEM101020 (original was PEM100990) with uprated intercooler and Nakatanenga fan extender.
Tested the configuration on Morocco desert at more than 45° C and the car was fine also on sand (mine is also remapped)
Soft spring configuration should be a problem during the winter with temp closer to the 0° C or below.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #745781 15th Dec 2018 10:42am
MK
Eduardo.
Is your egr inlet pipe blanked? Puma 110" SW
Post #745993 16th Dec 2018 2:02pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Any results with the Alisport radiator? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #750029 8th Jan 2019 7:08pm
Eduardo
Not installed yet.
Already bought but the funds for the installation was derived to repair the swimming pool Sad Eduardo
Post #750093 8th Jan 2019 10:47pm
Bergos
Come on! It's a DIY job! Bergos
Post #750145 9th Jan 2019 12:57pm
MK
in 88kkm I think happened twice I got into limp mode because of the cooling system is not up to the job under "demanding circumstances". I am planning to fit an adjustable electric fan controller that comes with a sort of temp probe sensor which is installed through the rad fins and of course I will try to use the A/C fan.
Anyway, I believe relay #6 located under the seat is controlling the A/C fan. Do you see a problem by wiring such controller into the same relay? does the original fan take more than 20 amps?
I´m quite incompetent when it comes to wiring (in other stuff as well of course)
thanks in advance
MK Puma 110" SW
Post #756333 4th Feb 2019 8:53pm
Eduardo
Finally I was able to install the new radiator.
So far so good!
Temps was not going over 96°C with a air inlet temp of 34°C.
Car medium load at 120 KPH in 6th gear in a mild lomg slope
Still I need to have more points to compare (higher temps)
Dgardel:
I have the "cooler" thermostat (PEL500110) not problem here with temps below 0°C, Allisport intercooler and the Nakatenga spacer.
I'm not using the remap now to see the behavior and do a VCV learning (still not done)
Cheers! Eduardo
Post #757972 11th Feb 2019 4:17pm
Eduardo
Second test
Tested again yesterday with inlet temperatures of 36°C, almost fully loaded in a highway were always develope this problem at high speeds (120 KPH).
Temperature never goes over 100°C staying more of the time in the range of 90-97°C. without the A/C.
So, appears that the radiator change have been the solution for my overheat problems Very Happy
Let´s we see next week
Cheers! Eduardo
Post #759384 18th Feb 2019 1:42pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #759386 18th Feb 2019 1:48pm
Page 2 of 2 <12
