Home > Technical > Windscreen washer twin jet head
Tractorman
Scotland 2011 Defender 90 Puma 2.4 HT Indus Silver
I have lost the twin jet head on my 2011 Hardtop 90 (Puma engine) - just left with the spigot sticking out of the bulkhead. I see that the replacement unit is part no. LR061677 which is the head plus spigot that the fluid delivery tube is attached to. It looks as if you need to get behind the dashboard somehow to replace the whole unit. My question is can you just remove the head from the new unit and simply snap it onto the existing spigot which is in situ?
Post #744498 7th Dec 2018 4:38pm
Blacksheep
Yes. Soak the new one in hot water before separating, try the “search” key, a common problem, lots of info on here. Time is precious, waste it wisely...
Defender 90 D200
Post #744502 7th Dec 2018 4:50pm
Tractorman
Many thanks Blacksheep - that has been very helpful
Post #744571 7th Dec 2018 9:41pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
You can, but at least on the older vehicles it had a habit of dismantling itself again. Not sure if the Puma ones are the same part, it's a newer LR.... part number. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #744635 8th Dec 2018 10:20am
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
Thanks, as always for the tips: I managed to separate the parts in hot water and re-attach to to what remained on the car (with some glue to try to keep in place).
Definitely saved time and effort Bow down
Post #770337 27th Apr 2019 9:32am
williamthedog
I hit the top of mine clean off with a foam brush back in the winter. I done exactly the same thing. Soak in hot water, line it up with what's left showing on the bulkhead and a smart tap with my hand and it clicked back into place 😁👍
Post #770350 27th Apr 2019 10:35am
