![]() | Home > Expedition & Overland > 130 camper/expedition.... preparation advice wanted |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Sounds a great trip. The only experience I have of RTT is the iKamper Skycamp, but it is brilliant, for sheer ease of erecting and pack down literally 30 secs. They are expensive (unless you find one second hand
![]() ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 ![]() |
she wants inside awning ladder i should have added
nice tho |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
take a look at this one and see the sort of things you can do to a 130 !!
http://www.ebay.co.uk/itm/2012-12-LAND-ROV...:rk:5:pf:0 ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 829 ![]() ![]() ![]() |
You cAn buy awning or changing room for an ikamper 👍
Howling moon , maggiolina, eziawn RTT also you can’t go wrong with Terese Also tufftrek are getting some good reviews esp the clam hardshell Have fun be happy |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 ![]() ![]() ![]() |
Sounds like a great trip. Ive got an Oztent and a Hannibal rear owning which is not what you want.
We have a Engel fridge I bought from MPS trading. Really helpful. I did loads of research on fridges. It was a toss up between a Engel and a Lunar. Engel where cheaper and they have only 1 moving part... low current draw and seems to last for ages....You can google them....... Twin battery setup from MobileCentre, Blue Sea stuff with odyssey batteries. The guys at Mobile Centre a really helpful bunch too. I hope this helps.. Cheers Richard |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
I've seen that, its Familmad off here I think. pure 130 perfection |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Trip sounds great, be careful, safe, and have fun! Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
If you just want a quieter ride when cruising at high speed (for a defender) you may want to consider changing your 5th gear ratio rather than using a disco transferbox that will change the drive ration in all gears Russell
2011MY 110 XS USW Black |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8362 ![]() ![]() ![]() |
for the quieter gearing or less rpm for a given speed - 285.75R16 BFG ATs or a similar 33" rather than t box or Q gears?
i would change wheel bearings from stake type nut to locking tabs and takes spares (stub inc) There was a post on here not so long ago of a free standing tent that carried on top of the vehicle, you set it up, dropped the legs and drove out. it had sides to go on it too, cant recall what it was called. batteries - get two Numax leisure batts from https://www.tayna.co.uk/leisure-batteries/numax/cxv30hmf/ or https://www.tayna.co.uk/leisure-batteries/numax/cxv35mf/. the two CXV30s will definitly fit. wire them together with a Durite voltage sensing relay. https://www.ebay.co.uk/p/Durite-072733-12V...amp;chn=ps which you can also buy as a kit https://www.ebay.co.uk/itm/261443494060 Fridge wise, i bought an Engel 45L one 10 years ago 2nd hand, works a treat, very low currant draw. try these guys for solar options, https://www.selectsolar.co.uk/prod/1189/se...100w-panel had mine from them for 2 years now with controller and no problems. take a bottle jack not a highlift. take a grill for cooking over open fire, get a halfords or similar tool box 200 piece with shadow board less likely to loose things, that a leather man plus anything specific to the vehicle (like 32mm hub nut socket!) Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
all great replies,just brought a fridge and am looking at a roof tent i think for this trip,will be looking at your solar panel/battery setup,got the halfords socket set already kelly kettle and watering can for showers worked great in maroc about 15 yr ago with my 110
i am seriously thinking of a roll cage for general safety as opposed to hard off road and swapping my alloys for some steel wheels a different canopy with side access able to take the weight of the tent and good locks is also wanted thanks loz ![]() Click image to enlarge |
hi further to your advice what rims do you recommend with those tyres i was looking to go with wolf rims but it seems those tyres would be too big thanks loz |
Mach 5s, rolled edge. strong, reliable and maintain a good bead at low pressure. your issue will be finding some! Cheers
ok thanks for that
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105 ![]() ![]() ![]() |
Hi lozza,
Welcome to 130 ownership! Just my experience/thoughts ![]() My brother and I bought Tuff Trek tents from the owner Dara (really nice chap with good products) and we've been really pleased with ours. At the time they were a cheaper option than the usual big names you see round shows but we couldn't and haven't found any drawbacks. We've got the optional awning that hangs from the unfolded part of the tent which is really useful too - it's nice to have a built in ground sheet so it's fully sealed. (Not got a picture of it with the awning up annoyingly) ![]() Click image to enlarge We run these split chargers - https://www.es-store.co.uk/product_details...ow_menu=10 I went with a Victron product as I have one of their inverters (we're a little power heavy preferring to run an electric kettle and even a microwave). These allow me to put my hook up charger on the auxilliary bank of batteries for house power, and the split charger will switch both ways according to whichever "end" is being charged. Another nice feature to have is an over-ride to be able to crank from the auxilliary battery if the main battery fails that necessitates a large current capacity. A pure sine inverter is always handy even if it's small - we normally get plenty of people we're travelling with asking to charge phones, cameras, laptops and all sorts once they realise you have 240V and means you don't have to worry about 12V adaptors for everything. I'd always recommend Odyssey AGM batteries as being a good bulletproof solution (I've used them on many a project for military applications at work) as long as you can afford them - I've still got normal lead acid leisure batteries at the moment just big ones for cost reasons. Whenever we go away I mount my tent straight on to the cage - I went for a safety devices cage but opted for the front half (over the cab) only. At the time it kept the price down for me which was much needed, but still means you can forget any worries you have about overloading the roof/canopy when you put people in the tent. We've moved as a family to fitting some form of roll over protection on everything now after seeing too many pictures of rolled Defenders. Wheels and tires, personally I'd stick with your blindos. I think I'm right in saying these are the same wheels used by the MOD which in my book makes them a pretty reliable option - I believe you can fit a wider variety of tire sizes on to a blindo than you can a steel aswell. I'd also strongly support JST's suggestion of bottle jack not high lift - I'm yet to have an occurence when we've needed a high lift. Maybe we just aren't travelling difficult enough trails! I've got this far just using waterproof boxes in the tub but a good solid canopy is definitely next on the wish list - the security problem wears you down after a while. The two thing's I'd advise above all else are a good set of tires, and a good set of shocks. Hope that's helpful! Joe |
