Home > Puma (Tdci) > Switchable low range map - anybody done this?
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
On the TDCi the tune/throttle map is different for low range and high range and the switch between the two appears to be controlled by a sensor on the transfer box.
The standard low range map is hopeless in certain off road conditions, far too unresponsive with the result that you have to anticipate a need for more revs sometimes seconds ahead, or the damping in the throttle map means that power delivery is too slow and you get stuck. Dropping the front end into a soft ditch is the classic example, where you drop gently into a ditch and then as the wheels hit the bottom, add revs to push through it. Suddenly hitting an unexpected soft patch in wet peaty ground is another, you boot the throttle and nothing happens for a second, which sometimes is too long and momentum is lost.
I've now got the BAS remap and I have yet to try low range in proper off road conditions to see whether it's different, but the fix that some have applied to standard vehicles here is just to disconnect the sensor which reverts the ECU map to the high range tune, which is much better for most of our off road conditions.
The logical extension of this is to divert the ECU input that normally comes from the t/box sensor to a switch, and have them selectable on demand, as there could be times when the high range map is a bit too sensitive. I can't immediately think of a reason why low range mapping would be used in high range, but the option would be there. I was thinking of doing this simply by finding another plug that would fit and running a pair of wires back up to a latching on/off switch on the dash somewhere.
Has anybody done this, if so did it work, and what type of plug is it / any pointers to suppliers? I imagine somewhere like VWP may sell something suitable, the sensor plug looks rather like the plug on the back of an indicator light, though I haven't compared them side by side. I presume it's a normally open connection, given that disconnecting the switch defaults to high range tune, and that it isn't necessary for the wiring or the switch to carry any significant current.
I can't see why it would not work but just wondered if anybody could confirm from having done it? ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #742926 29th Nov 2018 10:58am
Martin
Site Admin
https://www.defender2.net/forum/topic54410...nsfer+plug  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #742929 29th Nov 2018 11:07am
edo
Have the Bas remap (in 170 mode), will be off road on Saturday and will report back!
Post #742930 29th Nov 2018 11:30am
BogMonster
Thanks Thumbs Up
£60 for the switch Shocked ---
Post #742931 29th Nov 2018 11:32am
Martin
Site Admin
If you want a manual switch, you need your choice of switch and a male plug.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #742933 29th Nov 2018 12:05pm
Bridge the clutch switch and see if you like the changes, might be far easier and simpler and improves capability abd control in low range especially.
(I would recommend if you don't have diagnostics though, should you ever need to clear a code.)
I've ran mine bridged for a couple of years at least now, I too don't like driving charachteristics in particular low range.
And that increased reference and jerky throttle response. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #742936 29th Nov 2018 12:21pm
bankz5152
Just wondering but I dont really understand the point of this?
In low my throttle is sharp and super responsive and in high its smooth but still very responsive (TD5 btw, TD5inside tuned)
Post #743263 30th Nov 2018 9:00pm
AndrewS
If you drove a Puma you would understand Thumbs Up Laughing 130's have feeling's as well you know Smile
Post #743265 30th Nov 2018 9:07pm
BogMonster
Indeed Laughing
I had a bit of a run over some bumpy ground the evening before last and the BAS low range tune is much better than the standard low range so I am in two minds, but my first port of call is a query to BAS to see if a lightly tweaked version is possible.
I had tried disconnecting the clutch switch (used to do that on Td5s a few years ago) but it was awful, I hadn't tried bridging it though. ---
Post #743376 1st Dec 2018 11:50am
Yes, you need to bridge it on a Puma. They cannot be just unplugged without issues.
On a TD5 as you mentioned it I should fine just to un-plug.
Just a suggestion to toy with anyway. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #743444 1st Dec 2018 6:09pm
