![]() | Home > Off Topic > Possibly a dumb plumbing question? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
hi doc p.
think you've got a by-pass valve there so you're probably going to have to drain the whole system including the header tank. if you're talking about the main incoming water supply valve / stop cock then yes it's possibly passing. Assuming you do have a header or F&E tank as opposed to a closed / pressurised system have you simply lifted the float valve to stop the tank refilling? good luck. Last edited by Caterham on 30th Nov 2018 3:11pm. Edited 1 time in total |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7942 ![]() ![]() ![]() |
I'm no expert but it would seem to me the two valves are in parallel so it doesn't have a stop vavlve? If so you will need to drain the whole system
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Yes, we’ve got F+E tank in the loft.
Sounds like my fears are correct. These valves are hard to come by and our usual plumber’s younger than the valves!! I’m not confident enough to risk mucking about with such small diameter pipes, so I think I’ll have to ask him what to do. |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 123 ![]() ![]() ![]() |
Hi Doc, if you take the cap off the one on the right it might have a screw head on top of the spindle, screw it down clockwise to close it, the one on the left will close with the knob or adjuster, good luck ![]() |
doc p
you got similar valves both sides I presume? |
Not sure if it is the valves or radiator you need to replace.
If you can get under the floor, then use pipe insulation and freezer spray. You will have enough time to replace the radiator. If need more time replace the valve with compression end stops. Brendan |
Both flow and return valves in the same body (at the same end - in and out). Theres a length of copper pipe joined to the inlet hole of the valve which runs along inside the bottom of the radiator. The return is right next to it in the valve body but far away from where the warm water comes out of that piece of piping🙄 The pipe had dropped off the valve so the radiator wasn’t heating up! Friend of mine knows his plumbing. Had to screw down the balancing screw under the other cap as OJ suggests - which I didn’t realise! Got them off thanks to his and your help. Thanks all again for the ideas. |
![]() Never come across that before. I presume there's a by-pass feature in so much that if you remove that valve the heating still gets round the system? |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
you'll need to re balance the flow into that rad again when you re-install.
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
These valves are obsolete as you probably know. You can turn off the square headed valve and lock down the valve with the inset screw to change the radiator. You have to collect a radiator full of water when you crack the nut connecting the valve to the radiator.
To change the valve you will need to partially or fully drain down the system by turning off the water to the header tank and opening the drain valve on the system. You only need to partially drain the system if the radiator is on the first floor. You then need to fit a valve at each end of the radiator, extending the existing pipes behind the radiator as necessary. Not a big job if you have done plumbing before. |
J@mes Member Since: 20 Apr 2012 Location: Bomber County Posts: 36 ![]() ![]() |
My house was full of rads with this arrangement on, when I renovated I took the floor up and re routed the pipes to conventionally feed/return from either end instead as I pretty much new I'd end up doing it when one of the valves failed anyway.
British Gas had done a few before I bought the house, and had just clipped the new pipework along the middle of the skirting board. It looked terrible. ![]() |
