Home > Maintenance & Modifications > Dead battery
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Dead battery
This am, pressed the open button on the key fob, nothing, looked into the cab, red alarm light out.
Got in using the key. Everything dead, lights won’t go on, clocked stopped. Volt meter 0.00, so, dead.
Think I know what drained it, hooked the rear view mirror monitor / dashcam to a 12v direct feed to the battery.... doh! battery less than a year old.
Stuck the ctek charger on it.... strange things happening, DRL’s are flashing and so is the lheadlight dash light when I tried it, can hear a clicking in sync with the flights flashing while charging, assuming that this is the alarm signal but with zero power in the battery to fire it?
Going to leave it overnight to trickle charge and see what happens.
Few questions, when the battery comes up to charge, if is does, will the alarm sound? If so, don’t want to leave it over night because it’s bound to go off at 3am and wake everyone up...
Thoughts anyone? Dead drained battery. Car locked fine Monday night, all flashed as required.
Post #742979 29th Nov 2018 5:04pm
Cupboard
Most DRLs are controlled with a voltage sensitive controller so they're detecting the battery charging and think that the engine is running. That's to be expected.
Just to be sure that the sidelights aren't on too?
Post #742980 29th Nov 2018 5:09pm
2010Blackdefender90
Thanks, think it will take overnight to get a charge into the battery, if it won’t take a charge, then a new battery will be next Thumbs Up
Post #742981 29th Nov 2018 5:14pm
Caterham
I assume it's the original battery?
just changed mine to a silver Yasa (or something like that from Halfords).
seem alright but not started the engine since so can't be sure - looks nice though Rolling with laughter
Post #742982 29th Nov 2018 5:21pm
2010Blackdefender90
Nope, I changed the original last year to the same as you have, as that was dead, after 6 years.
Post #742985 29th Nov 2018 5:29pm
rallysteve
The Ctek might not be able to charge a battery from totally dead. Does it have a boost mode or anything?
You might find you are better off jump starting the vehicle first to get a bit of charge into the battery before charging with the Ctek.
Post #742987 29th Nov 2018 5:33pm
2010Blackdefender90
Ctek has a boost mode... got that on. any ideas why the alarm hasn’t sounded as it’s gone dead.... curious how that works. Now I’ve opened it with the key, when it comes back to a decent charge is the system, won’t the alarm sound, as the doors have been opened, but the system would not know or have been reset.
Post #742995 29th Nov 2018 6:21pm
jst
Have you disconnected camera live feed too? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #743020 29th Nov 2018 8:56pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
If you opened it with the key fob it will most likely have reset the alarm, if the battery has drained completely i would think everything will have reverted to stored fail safe settings
Thumbs Up
Post #743027 29th Nov 2018 9:08pm
2010Blackdefender90
Yep Thumbs Up
Post #743052 29th Nov 2018 10:20pm
2010Blackdefender90
Thumbs Up
Thumbs Up
CTEK won’t put any charge into the battery, going to try and jump it tomorrow, failing that, new battery.
Post #743053 29th Nov 2018 10:21pm
jst
get an airflow battery conditioner on the old one if it comes out. that will bring it back to life. in my experience, despite being shot down here before they are far better than any CTek i have used. i currently have 3 not working CTeks and run 5 of these Airflows, the oldest few must be 10yrs+ and still going strong. https://www.airflow-uk.co.uk/product/battery-conditioner/ Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #743057 29th Nov 2018 10:24pm
2010Blackdefender90
Thumbs Up
Post #743058 29th Nov 2018 10:25pm
OJ
Good tip James and at a much lower cost than the CTEK Bow down
Post #743131 30th Nov 2018 12:15pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Have you got a battery back up alarm sounder?
If yes, should have gone off unless the alarm sounder battery is also dead
Post #743135 30th Nov 2018 12:20pm
