Home > Puma (Tdci) > Odd power loss
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Odd power loss
Hi lads, I've an odd intermittent power loss on my 07 2.4 tdci, it drives fine most of the time but the odd time it looses power, as if it looses pedal with no power and struggles past 70kph but if I switch it off and on again it drives perfectly! I've changed all filters twice but it's still the same? There's no smoke, no blowing turbo noises either? I've replaced potentiometers in the truck accelerator pedals before but they gave a different symptom to this?
Any ideas?
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #742595 27th Nov 2018 7:24pm
hornet
Have you already searched the forum for VCV-valve? Sounds like a fuel-related bug. Is the error present in both cold and warm conditions?
Post #742795 28th Nov 2018 3:32pm
Fault codes?
Post #742830 28th Nov 2018 6:59pm
John64
Scotland 2008 Defender 90 Puma 2.4 PU Tonga Green
Mine was doing this. Eventually traced to slightly sticky actuator arm for turbo. Only sticking on last wee bit. Disconnected arm and worked it past sticky bit for a few minutes, that and a bottle of turbo cleaner in tank and it’s been fine.
Post #742834 28th Nov 2018 7:11pm
John110
No fault codes, or management lights, The vcv valve, i must Look into this and the actuator arm also.
Thanks for the replys
Post #742897 28th Nov 2018 9:59pm
Check the harness that runs to the turbo modulator, all the way from the ecu to the turbo. It is very common for this to chafe and short to the engine.
Post #742904 28th Nov 2018 10:35pm
