Home > Maintenance & Modifications > Selectable Twin battery setup with VSR
jst
i am planning on leaving a 90 for long ish periods where it wont be started/cant be plugged in to a charger.
i would like to leave the vehicle battery connected.
Would also like it to start when i need it
To overcome this i have fitted a durite three way switch to allow
Battery A only
Battery B only
Battery A and B combined.
Batts are fitted in parallel through the switch.
General driving around would be on A&B so both batteries are being charged.
when due to be left for an extended period i would change it to 'A'
on returning if the vehicle didnt have enough 'juice' in 'A' to start i could switch it to 'B' to start the vehicle then swtich back to A&B to charge both batts.
As others will be using the vehicle and thinking of the simplest way of doing it (as they may not remember to put it back to 'A' from A&B when leaving for extended period) i was wondering if i could fit a VSR between A and B without going through the switch?
You could then leave it on 'A' the whole time other than switching to 'B' to start if 'A' was too low. then switch back to 'A'
So on 'A' it would charge 'B' through VSR when the voltage was high enough (engine running) but disconnect 'B' when turned off.
Question is if it was switched to A&B through the three way switch what would it do to the VSR if both batts had 14.2v coming in not via VSR and VSR was between two +ve terminals of 'A' and 'B'
the three way switch https://www.ebay.co.uk/itm/111817493774 which is an MBB for A to A&B to B. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #742712 28th Nov 2018 10:05am
Cupboard
That shouldn't be an issue. The VSR will detect the high voltage, combine then you've got two current paths between the batteries.
The other option would be a VSR that's got a jump start facility like the Victron Cyrix series. Most of the time you're starting on Battery A, if Battery A is weak then push the manual link button and start from the combination.
Post #742729 28th Nov 2018 11:10am
jst
So vsr won't fail if 14.2v went the wrong way through it? Batt b to batt a Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #742791 28th Nov 2018 4:27pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Wouldn't a simple isolator switch on the pos feed between batteries do the same thing? Turn on switch for normal operating mode with both batts connected and being charged.
When your leaving the 90 for long periods, just isolate battery B. Then when you want to use it again use the switch to connect both batteries together again, in case battery A doesn't have enough juice.
steve
Post #742804 28th Nov 2018 5:43pm
jst
yep but then your draining B to A Steve, simialr to jump start only that B isint getting 14.2V into it at the time of switch Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #742822 28th Nov 2018 7:43pm
miker
A vsr like the victron cyrix (with the manual link button) is perfect for this application. The durite switch isn't necessary.
Post #742913 29th Nov 2018 7:48am
rallysteve
I run an albright HD isolator connected between my two matching batteries. This isolator is actuated by either a VSR which runs on the main battery side and connects both batteries to charge when the engine is running.
I also have a manual override switch which allows me to self jump start in the event that the main battery is flat or for use of both batteries whilst winching.
My manual switch is connected to both batteries so that the relay can still be operated if either battery is totally flat.
Post #742914 29th Nov 2018 8:32am
jst
So the victron allows two Batts to work independently too?, a, b or a and b? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #742915 29th Nov 2018 8:51am
JOW240725
This all goes over my head but I wonder if a small solar panel would be an option to top up the batteries whilst left? My father used to leave a panel in the back window plugged into the cigerette lighter, which was enough to keep his RR ticking over. James
Instagram @suffolk_rovers
Post #742927 29th Nov 2018 10:58am
rallysteve
No its A or A+B. I am a bit confused why you want to be able to select A or B. If A (main battery has gone flat) then you would just want to connect A and B to get an effective jump start. I would want the 400A version of that type if you want to use it for cold cranking.
Post #742928 29th Nov 2018 11:07am
Cupboard
The 230A one is rated at 500A for cranking so should be enough.
I don't know about the cheapo VSRs, but much of the decent ones are "dual sensing", that is they don't care which is the starter battery and which is the auxiliary battery. Once the relay has closed it won't make any difference which way the current is flowing, it's just a piece of metal.
Post #742942 29th Nov 2018 1:19pm
jst
Steve
mainly because if A is really dead i dont want B just dumping charge into it and then not having enough to start the vehicle.
If B is totally isolated and can be started without connecting to A this wont happen.
When you jump off another vehicle the other vehicle is usually running. i have found with a really flat battery i have had to leave the other vehicle (the jumper) running to help trickle the dead battery before the dead vehicle (jumpee) will start as the dead battery is taking all the 'grunt' from the running vehicle. Trying to eliminate this Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #743049 29th Nov 2018 10:16pm
jst
OK thank you that is key part i was after knowing. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #743050 29th Nov 2018 10:17pm
SteveG
You could put isolators on both negative feeds of both batteries. Isolate B if leaving it for a long period and still need power for alarm etc. In the event that A is drained, isolate A, switch B back and start, then when it’s running switch A back.
If you don’t need the auto switching of a VSR, in your use it doesn’t seem like you do, then the expense of a VSR with a manual switch appears to be unnecessary.
Post #743107 30th Nov 2018 8:53am
