|  | Home > Technical > Puma Forward Facing Load Area Seats - measurements needed |
| sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70      |   Click image to enlarge Hi Sonoronos, Some measurements from my Puma. Regards Fletch. | ||
|  26th Sep 2018 2:40pm |
| sonoronos Member Since: 30 Aug 2011 Location: USA Posts: 8  | Thank you, Fletch!! | ||
|  26th Sep 2018 4:06pm |
| sonoronos Member Since: 30 Aug 2011 Location: USA Posts: 8  | Hi Fletch - one last question for you - I'm trying to correlate some other measurements I've received from other kind folks like yourself.
 When you made your 17.5" measurement, were you measuring from line "A" or "B" in the picture below? I'm assuming "A", but I want to be sure     Click image to enlarge | ||
|  2nd Nov 2018 2:43pm |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1459      | Rather than worry too much about the measurements, centralise the whole support bracket to the cut out on the arch    Thats how most conversion places do it. | ||
|  2nd Nov 2018 6:39pm |
| sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70      | Hi Sonoronos,
 My measurement of 17.5 was from the nearest metal to the back door so that would be B Regards. | ||
|  2nd Nov 2018 7:14pm |
| rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945      | Re distance to seat belt mounting hole - there is a specific seat belt mount anchor bracket that fits the underside of the tub and is bolted to the rear crossmember.  Fitting that component will determine the "factory" placement of the seat belt mount. | ||
|  27th Nov 2018 12:41am |
| Spaniel Member Since: 18 Oct 2015 Location: Northamptonshire Posts: 4      | Have a look at Yrm Metals web site,
 "REAR SEAT BELT TO CHASSIS BRACKET FOR FORWARD FACING SEAT HDG" | ||
|  27th Nov 2018 8:28am |
| Posting Rules
