![]() | Home > Puma (Tdci) > foot well blower |
| jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87
is there any device on the market that deflects the air from the foot well vent to actually go in to the foot well and not straight at your leg. with the air con on you get frozen leg??
| AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128
Went to the DIY store and by accident saw that PVC 90° tube. Put it into the oven at around 120°C for some 15 minutes, that makes it soft like plastilin, with gloves formed to fit into the opening of the heating and along the center console pointing towards the bulkhead, sprayed it matt black, adhesive foam tape around it to seal the outlet, the air is distributed rather evenly and only the feet are warm. Home made, working though, and I have seen a lot worse DIY ideas. Did not take picture yet of the installed things.
BR Oskar |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
This is what I have done to prevent "Puma Leg"
Made out of an Aluminium Door Plate- bent at each end-Covered in some Black Gaffer Tape and then stuck on with some Gorilla Tape. Works a treat. Keeps feet warm or cold as required instead of my L leg and SWMBO's R leg. Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Mhmmmmm nice solution' I "buy" (only virtually
IID Pro MV License |
Thanks Guys
I will get industrious when I get a mo |
Took some pictures as well now. Have not figured out how to get a picture into the post...
https://www.defender2.net/gallery/index.php?cat=11857 |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
like this...
Click image to enlarge Mike |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
Im with Glyn left foot up on top off the hand brake for long journeys stops me burning my ankle on the bloody thing, when towing long distance the hand brake lever on mine gets really hot, Any clever people on here got a mod for that problem yet ?? If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384
Cut your left leg off. |
