![]() | Home > Maintenance & Modifications > Best upgrades i can imagine, all for £18 |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
+1 on the VW 99 relay
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Yes the relay is one of the cheapest /best modification you can do on your defender
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
what does the 99 do? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 ![]() |
the 99 does wonders for your windscreen wipers and washers
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Those look great.
I just treated my 🖤 Duchess 🖤 to a new stereo. Pictures will follow on my feed over the next few days.. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Just to enlighten you further . It turns your wipers into programmable intermittent wipers ![]() |
...and when using the washers the number of wipes changes depending on how long you hold the washer button rather than the standard 4 wipes no matter what.
That's sounds cool. How do you 'programme' it? Regards
What is the steering wheel controller for, stereo or phone?
Controls stereo, phone and ipad based sat-nav and dashcam all at same time.
Very instinctive to the point you dont realise you are doing it. Flick stalk into intermittent mode and back off when seconds pause you want has passed. Now set until you do the same thing again to change it. Its kinda automatic as you switch things on and off like that whenever the standard pause isnt correct anyway. |
Another way of thinking when programming the wipe delay on these 99 relays is to turn on the intermittent wipe then off, wait for the screen to "fill" with rain and switch on and leave on. I use this idea as it gets programmed to suit the conditions, you can soon alter the delay as the rain gets heavier or lighter. I very rarely use the other continuous wipe modes these days.
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Got a link to it please? ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Wow, that sounds great! Good luck with it all. Give us an update after you have been using it a while. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
