![]() | Home > Maintenance & Modifications > Colour temperature of LED Side Lights |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
They are near identical. Parked next to each other the only difference you will see is the actual light pattern on the lens due to the different LED layout and lens design.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
If you want some really warm white sidelights, try the Bearmach kit. North Cumbria Search and Rescue - Team Leader
Nodrog the great Member Since: 17 Mar 2014 Location: The kingdom of Fife Posts: 10 ![]() ![]() |
I have looked at replacing the spot lights, but there is a lack of information on the LED lights on offer.
Colour temperature, is very import, day light is around 5/6000 deg kelvin, which is a white light, 3/4000 deg kelvin is a yellow light, the other information is lumens, I.e. 18000 lumens is approximately 1000w tungsten for example. It would be good to see the manufacturers add colour temp and lumens to there products |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
Those Mini Union flag lights do look awesome. Not sure you could get them to work on a LR though. James
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 ![]() ![]() ![]() |
Ended up going with RDX just because the design is a sealed unit - I've also bought the taillights too (tis a shame about the Union flag lights though).
Thanks for all the replies. ![]() |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
I bought these as I prefer the 'warm' look. Sadly though I've had to replace 4 units withing 6 months due to misting inside. They are not sealed units and I'd dread to think what would happen if I actually got them wet. Luckily they have a 2 year warranty and they're not far from me... Just a word of warning really ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
