Home > Puma (Tdci) > 2.2 Puma Pilot Bearing
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Just after everybody's thoughts.
I have two 2.2 Pumas here one with the engine out and the other with the gearbox out and I have found in both the pilot bearings are shot.
Both have roughly 105,000 km on the clock. Both are standard in regards to mods.
Those not familiar with the Pumas they have a needle roller pilot bearing.
In my defender the failed pilot bearing has caused considerable wear to the input shaft on the gearbox.
I have been trying to source a sintered bronze pilot bush to no avail.
I have ordered a length of sintered bronze to make my own.
Has anybody else encountered this problem?
Mark
Post #741698 22nd Nov 2018 1:11am
MK
Pilot bearing can brake during gearbox removal or installation. I believe the cage is made of plastic. As for fixing the tip of the shaft I cannot help. Puma 110" SW
Post #741725 22nd Nov 2018 10:48am
Roy5695
I’ve just replaced mine with a new genuine one. Wasn’t anything wrong with it but while I hade the box off to do the clutch it made sense to change it.
A relatively simple process which could be done in an afternoon if you had the right tools and access. I’d stick with what was originally fitted and just ensure it’s greased properly upon fitment with the correct high temperature grease. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741765 22nd Nov 2018 4:57pm
NickMc
I always replace them with LUK or genuine- and yes nearly everytime you remove a box a roller falls out! The special tool from Land Rover is about £80 and worth the money!
Post #741916 23rd Nov 2018 7:50pm
Roy5695
I just used an internal bearing puller. The whole set cost about £35 on eBay. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741917 23rd Nov 2018 7:54pm
