Home > Maintenance & Modifications > Headlight query
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Headlight query
What was attached here?
Daylight running lights?
Post #741606 21st Nov 2018 7:34pm
leeds
Defender SVX headlight which has sidelights built into main headlight?
Edited to add, has the light got the letter A as light function code as I can not make out all the markings. A = position light, side light, parking light.
Brendan
Post #741612 21st Nov 2018 7:43pm
Badger110
Googling the SVX it does say they had additional sidelights incorporated into the main headlight.
I don’t know where the Function code would be
Post #741618 21st Nov 2018 8:14pm
leeds
If you look at the approval markings at the bottom of the headlight lens there is the country code E9 in a circle which is the code for Spain. To one side of the country code I can see what appears to be a 4 digit number which will be the actual approval number. On the other side there appears to be either HCR or HC/R which is code for dip and main beam either halogen or LED.
A is code for side light.
RL is code for a DRL but I do not think it will be that.
Brendan
Post #741623 21st Nov 2018 8:32pm
Badger110
There are a few numbers & letters
Post #741629 21st Nov 2018 9:08pm
leeds
It is difficult to photograph and make out all the markings
To the left of the country code E9 for Spain there appears to be
A which will be for side light
00 will be for the original amendment of the regulations
HC/R will be for dip and main beam
12.5 will be the Peak Beam Reference number
E9 Spain
6310 or 8310 is the approval number
Have a look at the rear of the headlight unit. It appears to have the main wattage values 55/60 watts and 5 watts.
Have a look and see what other markings are on there. Model number etc.
Brendan
Post #741654 21st Nov 2018 9:38pm
