Home > Puma (Tdci) > Judder in 5th and 6th |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
That’s what I eventually learnt about the springs. Mine had become ineffective.
Due to my remap I was pushing much more torque through a shagged clutch. Massive transmission vibration. I’d lived with it long enough, plus it had started to clunk on idle. Was only a matter of time before it wrote the flywheel off too I reckon. All sorted now though. Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
19th Nov 2018 5:00pm |
Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43 |
Hi Roy, yes we removed and checked the friction plate, the springs did not rattle but i was and i am not convinced they are 'right' . Only thing holding me back on a new clutch is i was hoping to put an auto in it and was waiting on the latest update from Ashcroft on locking the torque convertor in all gears of the 4 speed and was searching for feedback on the JE 6 speed. All input welcome! |
19th Nov 2018 5:42pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Sounds like an issue with clutch plate or uneven friction material 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
19th Nov 2018 7:34pm |
Whatever it was it’s now fixed. I did have the flywheel off to do the rear crank seal so maybe that was slightly skewed.
The clutch friction plate springs were very very rattly, the slave cylinder bearing was also very worn, I’m guessing from the rattly clutch smashing against it. Now replaced with a lovely LOF clutch. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
20th Nov 2018 10:40am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16888 |
Which spec of LOF clutch did you fit, and are you pleased with it?
Thanks. |
20th Nov 2018 11:28am |
I was advised that the Road spec would be more than sufficient for me, I had the power spec in the basket until Luke told me it wasn’t really required.
Luke the owner of the company is a real good guy and was more than happy to help and advise wherever I needed it. Even down to what bits I needed and the tools required to do the job myself. The actual unit itself is lovely. Good pedal feeling and a nice and smooth take up of drive. Still in the bedding in phase, only about 100 miles as it has an organic construction. But so far I’m enjoying the drive. The clutch pedal is ever so slightly lighter now as well I think. Which is a plus and will hopefully keep the wife’s leg happier. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
20th Nov 2018 1:22pm |
Thank you. My reason for asking is that my current clutch has now been in for 80k miles and is fairly horrible, although not rattling it is very evident that the springs have taken a set and it provides no torsional damping, so a new one is on the cards very soon. I was looking at the LOF options and trying which is the most suitable for my application.
My Defender has a mild map but is always loaded to around 2.5 tonnes gross, and the "power" option seemed to the be most appropriate, although as of this morning I can't see it listed. Since I imagine that the "road" option is the nearest equivalent to a normal LR clutch, probably this would be fine for me. I have to say that the prices seemed very reasonable to me too. |
20th Nov 2018 3:47pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3021 |
I second the recommendation for LOF clutches. Mine has been faultless.
20th Nov 2018 4:02pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Clutchfix have a long history of making clutches and not just for Defenders.
We send their clutches all over the world and we do not buy just one or two at a time Click image to enlarge They love a challenge when it comes to clutches. This clutch was a 17" double clutch from a 1950's vehicle that they were remanufacturing last time I was in their factory. The clutches can't be bad as they are made in Yorkshire Click image to enlarge So for a firm who knows clutches it is Ben and team at Clutchfix for me. Have a look here or here Brendan |
20th Nov 2018 4:18pm |
