Home > Maintenance & Modifications > Oil change frequency?
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Seems like clockwork that every 6 months I get an 'Oil Service' message appear in my dash message window. It's on again and I changed the oil at the end of March/beginning of April at the last service. Regular phenomenon for the last 2 1/2 years.
Presumably, the ECU has predicted (or calculated) excess diesel in the engine oil (> 7%?) again.
We do about 8500 miles/year which is mostly short hops/bit of off road (shooting). Engine is the 2.2 TDCI with 38k miles on it. I suppose the way it is used contributes to this.
Is this acceptable or is something afoot?
I suppose changing the oil every 6 months isn't a bad thing for the sake of £50.
Post #740927 17th Nov 2018 12:26pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I watched a youtube video, and it was the opposite almost... It was based in the States
Garages had been suggesting 6 monthly and in some cases 3 monthly, but actually it said to check the handbook - which in most cases stated to change yearly or 'X' amount of miles.
I have a TD5 - what does your manual state? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #740930 17th Nov 2018 12:46pm
Doc P
12,500 miles or every 12 months - whichever's sooner.
Post #740932 17th Nov 2018 12:53pm
Adam17
That's odd then, that your truck is pinging up every 6 months...?? Regards
Adam
Loving The Duchess
Post #740933 17th Nov 2018 12:59pm
grafty99
It's the ECU calculating diesel content in the oil (based on the number of active DPF regens) the only problem is the ECU will still count a partial/failed regen as a full one.
If it was part way through a regen and you turned it off then it won't have completed its cycle but will still count it as a full one.
Obviously doing lots of shorter trips will increase the likelihood of turning off during a cleaning cycle.
I definitely wouldn't ignore the light though. As you say, for the sake of £50 may as well get it done Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #740937 17th Nov 2018 1:24pm
Doc P
Thanks guys. Nice to know it's not necessarily anything 'bad'.
I'm getting it done Thumbs Up
Post #740938 17th Nov 2018 1:32pm
grafty99
1990 Vogue SE
Post #740946 17th Nov 2018 2:08pm
Cupboard
I was curious what the viscosity of diesel was compared to engine oil, in case I'm not the only one here goes:
10W engine oil at -18C is 1300 centiStokes
30 engine oil at +100C is ~11 centiStokes
(I think that's correct for a 10W30 oil?)
Then for diesel at 55C it's about 2 centiStokes
source: https://www.engineeringtoolbox.com/kinematic-viscosity-d_397.html
So it's quite a bit runnier even than SAE20 oil.
I wonder how the lubricity differs.
Post #740971 17th Nov 2018 5:52pm
jst
Change mine every 6k or so, 2.4. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740973 17th Nov 2018 5:58pm
williamthedog
Once a year, mileage 3-4k.
2.4 engine.
Post #740975 17th Nov 2018 6:02pm
NickMc
Oil is cheap- engines aren’t 6k change for me, just not worth it for the price of oil and a filter.
Post #741037 17th Nov 2018 11:40pm
Adam17
I guess that's a good way of looking at it. I am always up for preventative maintenance ... Regards
Adam
Loving The Duchess
Post #741066 18th Nov 2018 10:35am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Does the service light go out once the new oil has circulated the engine?
Post #741068 18th Nov 2018 10:40am
Martin 01
Around every 6000 miles for my Td5 as a few have stated already.
Oils & filters are cheap enough.
Not a great believer in these 20,000 mile services for modern cars.
Post #741084 18th Nov 2018 12:23pm
Doc P
It’s reset manually.
Post #741119 18th Nov 2018 4:49pm
