![]() | Home > In Car Electronics > 5 pin carling switch wiring diagram |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6730
What spec of switch are the second ones?
Off/On or On/On? Normal or momentary? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 294
Second switches are off on.... @steve_overland on Insta.
110 expedition vehicle with pop roof |
The first are from a company called on board air... so I’m guessing at not genuine .... @steve_overland on Insta.
https://www.mudstuff.co.uk/pdfs/Carling%20...202017.pdf
Gives 1: Power In 2: Power Out 3: Link to Pin 2 7: Earth 8: Illumination+ Your first switch appears to be a "Carling type"/clone as we discussed above. Follow landy andy's posted image. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Cheers Martin...
What does the link to pin 2 do ??? @steve_overland on Insta. 110 expedition vehicle with pop roof |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Its a bodge to make the indicator lamp in the switch work because the mudstuff ones are US spec. 02' 110 TD5 Double Cab Rebuild Thread
@Steve_Overland: have you got the Carling part code from the body of the switch?
2015 D90 XS SW |
1829 r @steve_overland on Insta.
Hmmm. Should be a code starting V1D?
Answer to your previous question is: I don't know what the link to pin 2 does - it doesn't match the expected working from Carling's own datasheet. Hence asking what the exact Carling switch code is so I can find it 1988 90 Td5 NAS soft top
2015 D90 XS SW |
V4d2 maybe @steve_overland on Insta.
Ok V4 are On-On type
Power in to 2 Power out to 1 in one position Power out to 3 in the other No link required. Check with a meter which of 1 or 3 is connected to 2 with the switch in your desired "on" position. The US/EU types available make this a headache too. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Is that still the earth and illumination as before...7 earth 8 from lights... 2 power in and then 1 or 3 power out.... @steve_overland on Insta.
Yep
2015 D90 XS SW |
Legend thank you so much..... @steve_overland on Insta.
| All times are GMT |
