Home > Maintenance & Modifications > new mudflaps for 110
Stacey007
I don't have front mudflaps and my rear brackets are not in great condition so been looking at these by a company called tuff rox?
anyone have them, seems they will not discolour like the originals. You can also choos any colour and the brackets are galvanized.
whats the verdict? Around£130 set of 4 with brackets and bolts
Post #740516 14th Nov 2018 5:55pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
After buying mine I saw these and wondered the same.
For a full set with galv brackets, the money is pretty good but personally I’d go with the blank ones
Post #740529 14th Nov 2018 7:06pm
Are the 110 rears an improvement on the originals from a structural perspective? If not then go for a set from Gwyn Lewis - galvanised, extremely well engineered, makes the mud flap easily removable and includes mud shield protection for the rear crossmember:
https://www.defender2.net/forum/post727189.html#727189 Darren
Post #740542 14th Nov 2018 8:10pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
As above I had a full set of Gwyn Lewis mud flaps fitted 4 years ago. No problems at all and the brackets still look new.
Post #740549 14th Nov 2018 8:33pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
I have bought a pair of their stainless steel gloss black brackets and fitting which are great for the front of the 110 when I fitted new mud flaps product are service was good but when I do the rears I am using the gwyn Lewis kit.
Post #740611 15th Nov 2018 12:47am
oneten110
They look too long, first time you reverse out of a hole you will rip them off.
Got Gwyn Lewis on mine as well and found it to be well thought out, robust and with clear instructions
Post #740629 15th Nov 2018 8:02am
Thon
Gwyn Lewis rear flaps also give you the option of removing them really simply if you are in a position to rip them off.
I have the fronts and rears, plus all of the mud shields fitted and only have praise for them.
That's not to say that the Tuff Rox ones aren't any good, but the Gwyn Lewis ones definitely are Thumbs Up
Post #740681 15th Nov 2018 2:55pm
jst
I just replace with std ones. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740695 15th Nov 2018 5:21pm
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Look good
, I have just replaced the back brackets with powder coated stainless steel ones from 4x4 overlander.
Post #740700 15th Nov 2018 5:48pm
Cupboard
Another +1 on the Gwyn Lewis kit, it's as good as it should be.
Post #740842 16th Nov 2018 5:31pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I wonder if this may be of interest:
https://www.defender2.net/forum/topic29386.html
I quickly took off the original rear mudflaps as the turbulence between them and my plastic liners made everything filthy immediately. I also extended the bottoms of the rear liners with some rubber sheet. They've been on for over four years now and still work very well.
I must point out though that the only time I go 'off road' is if I have to park slightly on a pavement or run onto the grass verge to allow other vehicles to pass on narrow country lanes. I would hesitate to go anywhere in it now that I'd have barely noticed on my trail bike many years back.
You can buy ready made rear arch liners here:
https://www.lokari.de/epages/62716287.sf/e...-0879-0880
Post #740872 16th Nov 2018 8:56pm
I'd forgotten all about your old thread, Joe. I've gone the full 'Gwyn Lewis' everywhere else but it's reminded me that I was going to make some flaps to shield the ends of the front bumper, so thanks for that. Darren
Post #740892 16th Nov 2018 10:57pm
Joe the Plumber
No problem Darren. The flaps I made to protect the front bumper have worked a treat over the years. I'm surprised Gwyn hasn't offered these himself.
I upgraded the bumper to a 5mm thick one from First Four Off Road a couple of years back, but the original one (coated in Dynax S50 inside from new) was still pretty much perfect when I removed it as the majority of the muck couldn't get in.
Post #740902 17th Nov 2018 8:38am
I've now fitted a galv bumper but I'd still like to keep the crud out of the exposed cavity. Darren
Post #740908 17th Nov 2018 10:17am
