Home > Maintenance & Modifications > Seat box corner protectors
Co1
I’ve got a split in the corner of a seat box and wanted to protect it before it gets worse. I’ve had a look online and for somewhere between £20 and £30 I can get some horrible cheap looking bits of plastic to protect. Does anyone have these and are they as cheap as they look? Anyone recommend anything else?
Col
Post #738934 6th Nov 2018 7:25am
LR90XS2011
I think Nakatenanga do some posh ones try Brendan DEFENDER 90 TDCI XS,
Post #738935 6th Nov 2018 7:29am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
I've got the plastic ones and once fitted you can hardly notice them, much better than torn corners
Post #738936 6th Nov 2018 7:49am
hank
I saw somewhere recently somebody used a black plastic external fascia like linked below
https://www.roofingsuperstore.co.uk/produc...black.html
I can't seem to find the thread/page now... Perhaps I dreamt it? Shocked
Post #738938 6th Nov 2018 7:56am
Me, too. They serve their purpose.
 Darren
Post #738953 6th Nov 2018 8:59am
williamthedog
I've got the plastic set as well. As already mentioned once fitted you hardly notice them Thumbs Up
Post #738955 6th Nov 2018 9:03am
bankz5152
+1 on the plastic ones. Do they job well!
Post #738967 6th Nov 2018 9:38am
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I’ve just put some layers of Gorilla tape on mine, they weren’t split but thought this would protect them.
Post #738970 6th Nov 2018 9:45am
hank
Is anybody aware of a similar product existing for the footwell/a pillar corner where the covering wears through?
edit: answered my own question - they do yes! https://www.ebay.co.uk/itm/283232867613
Post #738989 6th Nov 2018 11:16am
Co1
They actually look pretty good. I’ll order a set!
Post #738990 6th Nov 2018 11:23am
Cupboard
Mine were completely shredded and about 2 years ago I put some gaffer tape on them as a temporary stop gap measure.
The gaffer tape has survived much better than the original rubber stuff ever did and I've still not got round to fixing it properly.
Post #739251 7th Nov 2018 9:24pm
Pickles
These corner protectors are a very good idea, I've seen some affixed with double sided tape rather than drill holes in the seat box.
Pickles.
Post #739268 7th Nov 2018 9:57pm
They are good, but the screws are not so good in my opinion.
I found they wouldn't nip up at all, went in and sound spin and I certainly didn't overtighten them
And only happened with a couple.
Easily rectified but annoying. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #739273 7th Nov 2018 10:30pm
L110CDL
The corner protectors are good in what they do, but they are not kind to my door cards and the top of the corner protector in time Sad ........................
as you can see there is wear on the top corner and this is what my door cards are like now ...........
Yes you can not see the wear marks when the door's are closed but they are an easy spot when the door is open and very annoying when cleaning the door cards Evil or Very Mad Clayton.
Keeper.
Post #739274 7th Nov 2018 10:54pm
Mines pretty similar to that, and with Dynamat under too adds a mm or two.
Cannot understand why LR made the fit that close, this is why the rubber matting often splits on the corners too due to pressure on them from the door cards. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #739279 7th Nov 2018 11:17pm
