![]() | Home > Maintenance & Modifications > What would you replace after 10 years / 90K |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Been there, done that. Replaced all drive train. Shafts, bearings, hubs, UJs, CVs, drive members and all. Drives like a new one now. Peter
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
...& that's what I love about our Defender's, most other vehicles would be fit for scrap but good old basic engineering is so so easy to replace. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3858 ![]() ![]() |
Triggers broom
![]() If any one who has done it has a list of parts, recommendations or upgraded parts that would be good. |
as above been there.....
first port of call from what you mentioned - rear drive flanges if they've not been replaced recently. I'd suggest you look at some HD ones. I replaced with standard and from some reason they didn't last 5 minutes. as above done all the bearing too. if doing a diff refresh consider ATB diff? if you're going BIG do you need to think about clutch replacement? as you've said poly bushes ( ![]() inspect and protect chassis (inside n out) |
Thanks over my owner ship it has had some new calipers. front / rear discs and pads. Also pretty sure drive flanges and universal joint. These were done at a service one time. |
![]() from the description and the little time it takes I'd defo take another look at the drive flanges. I was amazed at how quickly one of mine wore. have fun. ![]() |
