Home > Maintenance & Modifications > Cleaning Chequerplate
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
My XS side steps are currently away at the stove enamelers for blasting, zinc treatment and powder coating. Prior to that I removed the chequerplate treads and rubber gasket. The treads are somewhat grubby (but not corroded) after years of use and I've not been able to remove it with a pressure washer. Does anyone have any recommendations for how to restore the chequerplate back to its original finish?
Post #738782 5th Nov 2018 4:08pm
gilarion
Alloy Wheel cleaner and a good pressure wash should bring them up. Also, try soaking them in coca cola (seriously) you would be amazed. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #738786 5th Nov 2018 4:30pm
Zed
If you have access to a steam cleaner they work a treat.
Post #738797 5th Nov 2018 5:31pm
Intercept
gilarion wrote:
Alloy Wheel cleaner
Thanks - do you recommend any particular product?
Post #738823 5th Nov 2018 7:18pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Solvo Autosol. Thumbs Up
https://www.halfords.com/motoring/car-clea...polish-75g
"Other suppliers are available"
Post #738831 5th Nov 2018 7:38pm
Intercept
After much fishing around the net I settled on this:
In conjunction with a stiff brush it does a great job. And you can legitimately claim that it isn't a Land Rover thing when the parcel arrives Whistle
I got mine from https://www.ebay.co.uk/itm/112337939932
Post #739475 9th Nov 2018 10:33am
You need to check if there is severe oxidisation first. If there is, use a scotch pad to remove it.
As others have said, alloy wheel clean first. The new Meguiars one works well I found.
Then polish with white diamond. This is a polish and sealant in one.
The effect from this depends on how much work you put in. If just a little it’ll look a satin brushed effect. If you work it all the way you can polish it up to mirror bright.
It’s something I need to do on mine, and is a perfect winter job to do when boredom sets in.
Also, what ever you use make sure you use in good ventilation as many of these potions are fairly aromatic. The white diamond has a vanilla scent too, just a bonus really and it does last.
But as I said lightly sand away heavy oxidisation first if any is present. Red then grey scotch pads are ideal or even 600 wet and dry in places if it’s really heavy first. Then from there you can polish upwards so to speak. Very similar to paintwork preparation really. I like to keep mine just between highly polished and natural. 👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #739543 9th Nov 2018 5:34pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
The classic Fire Engine folks - whose vehicles are often covered in bare aluminium often use Brown Sauce - seriously! Euro-Leafing to infinity and beyond.....
Post #740110 12th Nov 2018 8:22pm
That'd be the vinegar in it no doubt. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #740113 12th Nov 2018 8:28pm
Intercept
I know several drummers who use the same for cleaning cymbals.
Bicarb & white vinegar do make a good cleaner but the main active ingredient in BKF is oxalic acid: https://en.wikipedia.org/wiki/Bar_Keepers_Friend
Post #740203 12th Nov 2018 11:22pm
