![]() | Home > Technical > Swapping rear panels. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
Nice to see your back Andy
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Thank you. I’m glad to be back.
It had to be a Td5 ![]() ![]() ![]() |
I was also fearful of doing it to be honest. I’ve only had the truck less than a month, and then pumped a load of money into buying the panels and having them sprayed. But, to be honest it was easy. Just take your time and be methodical about it. Fitting ones with windows would be easier than the other way (which I did) as you can look through glass and see what’s going on inside. I was blind as to what the brackets were doing.
BlackFender Member Since: 01 Nov 2018 Location: Vienna Posts: 13 ![]() ![]() ![]() |
Hi Shaun,
I want to swap my right (drivers side) with Masai fixed dark rear window one with a utility side panel! ![]() Peter 2013 110 TD4 SW Utility 1997 110 Tdi300 Hard Top 2013 90 TD4 Hard Top (trashed) |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5353 ![]() ![]() |
great idea on lifting the roof
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
If you cannot afford New panels, the panels from a series 88" hardtop or station wagon are the same size. I have a pair from a series 2 fitted to my 1984 CSW. Fitted them about 20 years ago. |
