Home > Maintenance & Modifications > Genuine LR Mantec Swing Away conundrum
CarMan
So, finally got around the getting it fitted a whole year after Dan supplied and there appears to be a puzzle Rolling Eyes
If I fit the Wolf's straight onto the studs then the back of the wheel does not fully locate onto the unthreaded part of the studs, so if I fit a nut on the back to keep the tyre off the carrier then the threaded studs are too short to fit the nuts on even half way. I know the HD wheels are thicker but it's more then that.
So, what am I doing wrong and/or what is the solution.
Part number is VPLDR0130 and these were ordered for steel wheels so assume that is what I got.
I'm thinking this would solve, but is it necessary Question
https://www.ebay.co.uk/itm/VPLDR0130-Alloy...:rk:9:pf:0
Any help much appreciated Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #738417 3rd Nov 2018 4:24pm
What tyres do you have fitted? It's possible that it only works as designed if the tyres are 7.50's, which were the standard fitment on the Wolf wheel. If you've 235/85's or even wider then they won't sit in the same place.
Having said that, if the tyre is clamped tightly to the carrier and all other clearances are ok (rear wiper?), then I wouldn't worry about it. Land Rover wheels sit quite happily on the threaded studs on just about every standard wheel carrier bracket they've ever made. Darren
Post #738421 3rd Nov 2018 4:55pm
Cupboard
I haven't tried it with my Wolfs, but it doesn't work properly with 7.50s on a standard steel wheel either. I've put nuts on backwards to hold the wheel out a bit and accepted that the main nuts on the outside doesn't fully engage.
Post #738450 3rd Nov 2018 7:50pm
CarMan
Thanks LRA - tyres are 235's.
So, if I understand your point it would correct for the tyre to be against the carrier and then tighten the nuts even though the back of the wheel would not be up tight to the unthreaded part of the carrier stud?
Cupboard - seems like they aren't fit for purpose which seems odd Whistle
Any thoughts on the alloy extenders Question
Post #738451 3rd Nov 2018 7:54pm
NickMc
Just wondering - Could you put the wheel on back to front?
Post #738479 3rd Nov 2018 10:59pm
PaulMc
You need the thin spacer nuts - KTD500100
https://www.brit-car.co.uk/product.php/173...ention_def
Callout 7 here -
http://new.lrcat.com/#!/1235/6103/6109/533
. Paul.
Post #738490 4th Nov 2018 1:56am
CarMan
Nick, I tried that and it does solve the problem but leaves the wheel a long way away from the back door which doesn't feel right and I'd need a spare wheel cover which has never been my preference.
Thanks Paul, I'll give those a go, though it does seem there may be no happy compromise between the tyre not touching the carrier and leaving enough stud to get the nuts properly on.
Confused
Post #738504 4th Nov 2018 9:56am
Yes, exactly. In fact, given what Cupboard says about the fit with 7.50's, it's almost certainly designed to be like that. The dimensions of these things have remained unchanged for decades, so if there was a problem it would have become apparent long before now. Darren
Post #738510 4th Nov 2018 10:12am
UtilityTruck
I have the same carrier, although supplied by Mantec it isn’t the same as the commercially available mantec carrier- this appears to be one of the limitations.
I have my HD steel wheel (with 235/85r16) on the door backwards to solve it, it’s not an issue for me - although I do need to get the inside of the wheel painted! 2014 Keswick Utility 2.2
Post #739147 7th Nov 2018 8:04am
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
I had a similar problem, the 235/85 on boosts would clash with the frame before the wheel studs went tight.
i bought the £30 adapters you linked too on Ebay, works a treat although the tyre could be a little tighter on the carrier. there is about a 1" gap as it sits now.
Mike
Post #739179 7th Nov 2018 1:45pm
