Home > Technical > 2.4 Puma 2010MY running cold |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2004 |
Hi James, surely changing the thermostat is the best place to start.
1st Nov 2018 11:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
Is there any possibility it has that waterless coolant stuff in it?
I don’t know much at all about it to pass much comment but just something I thought of. Other than that sounds like the thermostat as you mentioned. Have you tried bleeding it just to be sure too? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
1st Nov 2018 11:40pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
It's not running Evans waterless, it's running colder by 50% too. Waterless drops it 10~15%?
Thermostat is my thinking as I just can't get my head around why it won't get up to temperature unless it's been overcooled and thermostat is the only failure I can think of that would cause this. If gauge was reading low and engine was too hot then it would smell hot and measure hot on thermometer. If coolant pump had gone or air lock it would be too hot and I wouldn't see the drop in temp on gauge once it Had been worked. Nor would I see stat working and heat change across the rad. Same for a partial obstruction in cooling system. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Nov 2018 8:54am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
Sounds like failed thermostat (open position), or no thermostat fitted to me.
2nd Nov 2018 9:14am |
Just picking brains and i concur, But rad is cold until shes worked hard to temp, then rad is hot at top, cool at bottom. I am confident it's in there. Just not working correctly?
IS there any other reason why she would run cold? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Nov 2018 9:18am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1571 |
Semi faulty water pump? Some of them aren’t great quality, seen el-cheapos with plastic impellers that get loose when warm- real head scratcher that
I always find the infa-red thermometers are great for these kind of faults and are very cheap on amazon and the like- great tool for the box- and it’s got “a fricken lazer beam man” |
2nd Nov 2018 8:59pm |
have been using the infa red thermometer to test to date.
if impellers were the problem i would have slower coolant flow and then hot spots i would of thought, it doesnt seem to do this. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd Nov 2018 10:58pm |
Changed the stat, works a treat and temp sits at half way now. Thank you all Cheers
6th Nov 2018 7:48pm |
Glad you got it sorted James.
6th Nov 2018 9:17pm |
6th Nov 2018 9:49pm |
