Home > Maintenance & Modifications > uneven height after new suspension install
SkyFallSilver
Kuwait
Hello,
I have recently changed the springs & shock absorbers on my defender 90 2013 along with the anti-roll bars and noticed the uneven height of the suspension(right side of the defender is higher than the left).
Are there any adjustments that can alter that or adjusting the anti-roll bars.
Thank you in advance, 2016 Defender 90 Adventure Edition
Post #737978 1st Nov 2018 12:35pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
I heard there are left and right springs
I am about to do the same thing but all my springs look the same?? So interested in someone more knowledgeable to respond.
Post #737984 1st Nov 2018 12:53pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Defender springs are handed and colour coded (stripes down the coils) someone will be along to explain the codes I expect Very Happy
Post #737988 1st Nov 2018 1:03pm
dorsetsmith
spring colour coded
https://www.defender2.net/forum/topic41247.html
your in luck around right way Thumbs Up
Post #737989 1st Nov 2018 1:06pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
so that when the driver is sitting in the RH seat, it probs sits level. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #738034 1st Nov 2018 4:40pm
SkyFallSilver
Kuwait
dorsetsmith wrote:
spring colour coded
The setup i have are eibach springs and bilstein shocks, i will check with the installer and see how we can improve the stance. 2016 Defender 90 Adventure Edition
Post #738134 2nd Nov 2018 6:47am
Co1
Let us know how you get on.
Post #738135 2nd Nov 2018 7:08am
dorsetsmith
Banging Head
Post #738139 2nd Nov 2018 7:59am
SkyFallSilver
Kuwait
Figured out the problem for the un even height as the rear right spring wasn't sitting properly on top and now is sitting as it is meant to be. All corner's are same height. 2016 Defender 90 Adventure Edition
Post #738529 4th Nov 2018 11:49am
