![]() | Home > Maintenance & Modifications > Spray for rear crossmember |
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250
Having just done my hockey arms I'd say wire wheel in either brush or grinder. Grinder will be faster for large areas. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245
I've found the abrasive bristle brushes really effective at removing rust whilst leaving an even finish.
http://3mcollision.com/3m-scotch-brite-rol...grade.html |
| johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006
Finally got round to cleaning up my angry member before the weather turns.......Buzzweld RCP and CIO, Not too bad a finish, I sanded it down to silver metal.... 2008 TDCi 2.4 XS CSW
Bah.....forgot the pics..... 2008 TDCi 2.4 XS CSW |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2008 TDCi 2.4 XS CSW |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
nice job. well done. |
| dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237
Great minds! I did mine yesterday for the same reason. I used Eastwood Extreme Chassis Black, which seems to be a bit darker than Buzzweld
Looks good
After replacing the mud flap mounts with new ones, it seems to emphasise the buzzweld black as not quite black, is that normal, is the CIO a final coat, or is it meant to be over sprayed with a 'black' black ? Click image to enlarge Click image to enlarge JD 2008 TDCi 2.4 XS CSW |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Are the mudflap mounts Genuine?
They look very shiny. Probably dull and corrode soon anyway. From new they never matched the crossmembers. We all need to remember that is a chassis crossmember and not a body panel when discussing finish. |
| AdamGT3 Member Since: 18 Oct 2016 Location: Beaconsfield Posts: 22
How many aerosol cans of RCP and CIO do you need for the rear crossmember and how many aerosol cans of Dinitrol3125 for the inside of it?
Thanks |
| All times are GMT |
