Home > Puma (Tdci) > OIL DOES IT MATTER !!!!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Hi all, just doing a engine oil change on my TDCI 2.4 having a job finding castor magnetic 5w-30 A1 which i have aways used can i use any 5w-30 ???? or any recommendations
thanks buny
Post #737353 29th Oct 2018 11:15am
MartinK
Pop your vehicle details into the Opie site
https://www.opieoils.co.uk/
Use "DEF2" to get an extra 10% off at the checkout.
They sell "standard" and "upgrade" oils...
They have the Castrol (now "A5") for £56 for 2 x 4 litres (and you get another £5.60 off with DEF2 discount code) Thumbs Up You will have some spare for top-ups, or to add to your oil change next year...
This linky may take you straight to the engine oils https://www.opieoils.co.uk/f/2354/21453/2011/engine-oil.aspx
Torque settings here https://www.defender2.net/forum/topic8707.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #737357 29th Oct 2018 11:36am
bunnyman
cheers Martink all ordered thanks for the quick reply
Post #737361 29th Oct 2018 12:12pm
MartinK
Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #737364 29th Oct 2018 12:25pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Castrol magnatec 5w 30 a5 4L
Castrol magnatec 5w 30 a5 4L £23 Amazon free p&p
Post #737551 30th Oct 2018 11:22am
MK
Some users (2.4 engine) in this forum are using thicker oils such as 0w40 and 5w50. Puma 110" SW
Post #737651 30th Oct 2018 7:42pm
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
At a consumer level you are unlikely to notice much between any brand that meets the specification so I wouldn't get too hung up on Castrol.
Thereafter it becomes a matter of perception and brand loyalty. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #737798 31st Oct 2018 2:21pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Re: OIL DOES IT MATTER !!!!!
thanks buny
You have to use WSS-M2C913-B/C/D which translates to Castrol Magnatec 5W30 A5
Do not use ANY oil that is not WSS-M2C913-B/C/D compliant. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #737799 31st Oct 2018 2:31pm
Stu_XS
There are many oils that meet WSS-M2C913. It’s not just Castrol, which is exactly what I’m eluding to in my post above.
If it meets the spec it will be fine. Stu...
Post #737800 31st Oct 2018 2:37pm
Bergos
Sure. My point was - do not use other oils than WSS-M2C913-B/C/D.
I was sure that 5W40, 0W40, 5W50 would be better but it seems not to be the case with this engine.
Any other oil would decrease fuel economy, increase engine temperatures and in long ter do Censored . Bergos
Post #737801 31st Oct 2018 2:40pm
Bluest
In a 2.4 the Ford requirment does not really matter. In fact the best quality 5w30s may not meet that standard. The Ford specification for the 2.4 Puma is calling for a fuel economy oil for emissions and economy reason, not because it best protects the engine. There are better quality oils, in terms of engine protection, avaialble from Fuch and Motul and others that don't meet the Ford standard. I am not saying the Ford standard oils are bad, there are many good ones, just that in a 2.4 you don't need to get hung up on finding one that has the Ford approval on it. Any good modern fully synthetic 5w30 is OK. I would be cautious of using a different grade though. What the problem being solved by doing so?
The above doesn't apply to the 2.2 which has trhe DPF with special oil requirments. 2007 110 TDCi Station Wagon XS
Post #737808 31st Oct 2018 3:43pm
MK
The only advantage I can see is a higher HTHS value. That said, I do not design engines and Im not tribologist. Puma 110" SW
Post #737821 31st Oct 2018 4:38pm
BrickBox
For anyone interested for emergency- I was caught short on needing to top up my oil. In desperation I went down the car isle in home bargains and they actually had the required oil for the 2.4 TDCi..! £6.. M2C913-B 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #962580 23rd Aug 2022 12:07am
AMBxx
Good to see Rock Oil! My uncle's wife's father founded the company, uncle took on the running some time after marriage.
Uncle now dead, but 'Aunty Barbara' is still the Chairwoman. I think my cousin is still the MD/CEO too.
Post #962596 23rd Aug 2022 9:02am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Deleted
Post #962602 23rd Aug 2022 10:10am
