Home > Td5 > Doors not latching
Page 2 of 4 <1234>
srod
The relationship with temperature is spot on! I had this exact problem during the cold spell last week, I never got round to doing anything about it, and now the weather has warmed up a bit the problem has fixed itself....
Post #577723 14th Nov 2016 12:39pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
It's to do with the viscosity of the grease/lubricant. The latch depends on what is in reality quite a small, light spring. It doesn't take much at all to gunge it up.
I just used a PTFE-laden lubricant (GT-85) rather than grease and I've never had a problem since - either on my Td5 110 or on my Puma. On the latter I pre-empted the problem by flushing out the factory grease from new - it only takes a few seconds per door.
I have also replaced the front door latches with the X-engineering ones but not because of poor door latching. No, it was because I'd managed to ruin six pairs of jeans on the existing latches Big Cry Never happened on the Td5 at all but on the Puma...
The X-engineering latches aren't really a fix for poor latching unless the old latches are damaged - the plastic/nylon covering shredding for example. In which case new standard latches would work equally as well. But they wouldn't last as long and the pile of jeans with the torn out pockets would continue to grow. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #577727 14th Nov 2016 1:07pm
Romadog
Did mine and hey presto doors close much better !
My neighbours 90 had same problem - was going to change catches for new genuine ones, but after fitting the x-eng latch there seemed to be no need. However after a week the issue came back and I went round as the Font of all knowledge, did this spray exercise with both doors and they couldn't get them to fail. Didn't natter how many times they tried. Even had a text this morning to say that all was functioning correctly today too !!
Post #577774 14th Nov 2016 7:14pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
It's also worth taking out the stiffening from inside the door seal - just above the locks on the curved section.
Post #578302 16th Nov 2016 10:03pm
AJC
I'll be trying this myself, thank you
Post #578371 17th Nov 2016 9:04am
paullo
Canada
Result!
Just got back from freeing my passenger door from it's years-old issue. Originally started as a only-in-winter problem and the developed to an all the time thing. Now it's back to near new!
Thanks for the tip.
Post #579221 20th Nov 2016 6:37pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Just joined the Door Catch Club,
Passenger door took ages/attemps to latch, had problems with drivers door allso, so its of to motor factor tomorrow to get some brake cleaner.
Post #581972 1st Dec 2016 6:36pm
srod
First frosty morning Shocked this morning since doing this fix, and yes - it works!
Post #600021 8th Feb 2017 9:05am
nosnibod
Thumbs Up
Every autumn I now give the latches a going-over and coat the door seals in silicon.
...and apply lashing of ACF-50 over everything else... Dave
Post #600022 8th Feb 2017 9:12am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Superb!
The magic spray works! The recalcitrant 2nd row door that has bounced since acquiring the truck a few months back now shuts perfectly every time Very Happy
Many thanks for this solution!
John
Post #605709 1st Mar 2017 11:02am
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
I have this same issue but the original link to the thread no longer works... can anyone explain what it said?
thanks
Ross
Post #673656 27th Dec 2017 8:26pm
nosnibod
Hi Ross,
If you look upward into the door latch mechanism from below and operate it a few times you'll see a pawl moving on a lightly sprung pivot that catches on the main latch. That pawl is the one that gets gunged up so use a light spray lubricant (WD40, GT85 or similar) to blast the old grease and gunge out until it moves freely.
Once it's moving nicely lubricate it with something nice and light - definitely not a spray grease otherwise you'll end up back at square one. Dave
Post #673672 27th Dec 2017 9:53pm
landy andy
Ok. So what’s the trick?
Link to the solution has been removed.
Do I just spray loads of brake cleaner into lock to wash out old grease, then relube with lighter oil?
Mine is my drivers door, so is areal PITA at the moment.
Post #737281 28th Oct 2018 7:58pm
nosnibod
Just spray UPWARDS into the lock mechanism until it frees ups and clicks nicely.
The best way to judge your efforts is to operate the door catch with your finger whilst the door is open. You’ll soon get too see how it works and what needs to run freely. It’s not the main catch that’s the problem, it the one that pivots at the top that has a very light spring and gets gummed up.
You will hear the difference as things start to work better. Dave
Post #737302 28th Oct 2018 9:33pm
landy andy
Thank you.
I noticed the other day that it’s clearly been well lubricated over the previous years. It’s heavy with white grease.
Post #737305 28th Oct 2018 9:50pm
Page 2 of 4 <1234>
