![]() | Home > Technical > Swapping rear panels. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5900 ![]() ![]() |
Wow. Looks like I will be the first to do this then.
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
It can be done by unbolting the roof from the sides and then easing the roof up enough to swap the panels over. Prop the roof with some timber - it only needs to be lifted a couple of inches. You'll have to take out enough of the roof to give access to the bolts, which will be at least the rear and centre sections. Darren
Thank you. Fixings for ceiling are reusable or should I buy new for refitment.
Andy. |
You should be able to reuse them if you take them out carefully. I've had the lining out of mine twice and reused the fixings without issue. Darren
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1886 ![]() ![]() |
Fixings are reusable - just nuts and bolts.
I did almost the same thing last week (some pics on my 'tinkering' thread - in my sig below). I wasn't replacing roof panels though, just adjusting them, but it's effectively the same thing. You might need to get your roof a little higher to be able to clear the corner fixings in the tub. Good luck! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
This is a pdf that was sent to me from Bearmach. It is for a 110. Sit down when you get to the prices!
https://www.defender2.net/gallery/albums/u...armach.pdf Peter |
Thanks. I’ve got the panels, and had them sprayed for me.
Here we go then.
![]() Click image to enlarge Should have bought new fir fixings for ceiling lining though. Everyone apart from two snapped. I’m sure I would have had more success if it was above 3degrees C today ![]() ![]() ![]() ![]() ![]() Andy. |
That’s better
All done and I’m much happier with it.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 824 ![]() ![]() ![]() |
Looking great
Looks very smart
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Very nice work.
Thanks I’m very pleased with how it looks.
Got to clean the CSW rear panels up, and get them listed for sales to get some of the outlay back now. Andy |
