![]() | Home > Td5 > How cold should your bottom radiator hose be ? |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
My experience is the same, even with a new thermostat. I think it's a simple case of the engine not putting out enough heat to get the thermostat fully open in most scenarios.
I have watched temperature on my nanocom and seen it oscillate around 90 degrees quite happily. Realistically, the coolant system is sized for driving fully laden with 3+ tonnes on the back, in 35+ degree heat. October in England without a load on? less so! |
