![]() | Home > Pictures & Video > How cool is this?! |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
To answer your question, very cool
![]() Imagine it kitted out as an overlander. Imagine it on the school run ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
That is very nice
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 411 ![]() ![]() ![]() |
I think his last line sums it up -
"I want one, i've no idea what i'd use it for, but i want one." Me too ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
"basically......."
Very cool.
Couple of thoughts. What have JLR replaced it with? Be interesting to know if it’s a more modern Def (Puma 2.2?) modified in the same way, or something else entirely? It wouldn’t be a little ironic if on decommissioning Defenders they used a Defender (being the world’s most versatile vehicle) to become the replacement. ![]() Those 300W halogen search lights would be good for reversing in the dark. Wonder if FlatDog stock them? ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
I look at that and think....turning circle
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Or for £22k you could have a bit space in your camper, seat 9 and still have the red paintwork....
https://www.ebay.co.uk/itm/Mercedes-Benz-U...:rk:3:pf:0 ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
It is certainly eye-catching but I have to say that whenever I see a 6-wheel Landrover all I see is an example of starting with the wrong base vehicle.
The only possible reason for adding a third axle (apart from purely cosmetic reasons) is to increase the permissible GVW, and if you're doing that to a Landrover of any type you should have started with a stronger vehicle. I can understand LR building this particular vehicle since it was for their own use, and starting with a 5-tonne-plus GVW base vehicle, which would have been the sensible thing to do, would be seen as an admission that the Defender wasn't suitable, a message that LR wouldn't want to give. Every performance aspect of the Defender has been compromised by adding the third axle, tyre wear, handling, off-road capability, etc. The only thing it can to is carry an extra tonne of water (without the tank full the GVW is within the limit of a standard Defender with HD suspension). But it does look cool and turn heads, that is undeniable! |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Stage 1 V8
![]() Click image to enlarge ![]() Click image to enlarge Euro-Leafing to infinity and beyond..... |
^^^ i have to say that that is much cooler
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Ay! its great, I watch it on youtube last night..
Very interesting.. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1771 ![]() ![]() |
Not quite as cool as your avatar Clayton ![]() |
The sad thing about it is that a perfectly good Stage 1 V8 died to create it, and whilst it looks quite cool I bet it is awful to drive and of fairly limited usefulness. If it had been built on a two-axle 5-ton 4x4 chassis it would be a whole lot better and there'd be a highly-desirable Stage 1 V8 on the road still.
