![]() | Home > Puma (Tdci) > Turbo knackered, or something else? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Bluest
I think Capelandy had the same problem time ago. http://www.defender2.net/forum/topic3577.h...ngine+dust Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4321 ![]() ![]() ![]() |
Thanks Eduardo. It's hard to tell from that thread whether the issue was dust something unrelated to do with the EGR or PCV systems. It's ashame the photos have gone as I would have like to compare it to my own intake. However, it doesn't sound like the same symptoms as I have had, no mention of smoke.
I appreaciate my first post was bit of a ramble! And this one! What I'm trying to understand is what might be damaged/leaking to cause the blue smoke? The symptoims are blue smoke only on the first substantial acceleration after the car has been switched off more than a day or two. No smoke in normal driving or at idle that I can tell. No smoke if it has only been a short while since I last drove it. Engine runs fine, no fault codes according to the Nanocom. My basic understanding is that it can point to turbo seals, but could it be indicative of anyhting else? It would suggest to me that oil is slowly seeping into the inlet or cylinders someway or other whilst the engine is off. Are there any other routes via the cam cover or injectors or something? Would the turbo seals be damaged by dust bypassing the air filter? Is there any kind of logical diagnostic process to isolate the problem? 2007 110 TDCi Station Wagon XS |
Maybe this thread (stolen from other group) can help
https://www.stdrivers.co.uk/forum/topic/23...-start-up/ Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
Blue smoke after start up usually indicates valve stem seals.
Could be, how does one diagnose such things? 2007 110 TDCi Station Wagon XS
