Home > Technical > Steel wheel painting
Bps
Planning on blasting and painting a set of steels that I have and wondering what primer to use. I was thinking of zinc primer but wondered what other people had used. I want to paint not powder coat
Brad
Post #735479 18th Oct 2018 8:47am
JOW240725
I'd recommend speaking with Craig at Buzzweld, he does a range of excellent paints. I suspect a RCP primer would be good. James
Instagram @suffolk_rovers
Post #735483 18th Oct 2018 8:54am
Bps
Cheers just got in touch with them ๐Ÿ‘
Post #735510 18th Oct 2018 11:30am
What was their advice?
(Others may be considering the same question)!
Post #735515 18th Oct 2018 12:02pm
Bps
To use there rust encapsulator as primer base coat which is handy as reading up on it itโ€™s also good for chassis stuff. Will either go for aerosol or tinned and blow over with a spray gun. Not decided on top coat yet. Currently got wolf wheels in nato green satin so may go for the same on my mach 5โ€™s as green wheels suit the truck ( ex mod) and break up the black of the wheels a bit
Post #735519 18th Oct 2018 12:16pm
Thank you! Thumbs Up
I thought that "Rust Encapsulator" might feature in their reply.
I have a set of wheels to paint for use on a Series 1, hence my interest in your question.
Post #735532 18th Oct 2018 2:59pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had my series one wheels shot blasted. I picked them up then took them to the garage and covered them under a blanket. Two days later I went back to them and panicked as they were still bare metal and were showing the first signs of rust spots appearing!
I coated them all with zinga {from frost.co.uk} thinned down and sprayed through my cheap and nasty air compressor tool kit sprayer(Clarke)
Now its primed and painted and im confident they will never rust again. 1953 80"
1987 mini city e
2011 90"
Post #735635 18th Oct 2018 9:58pm
Cupboard
When I had my steel wheel blasted they were primed in a grey primer at the same time as part of the service.
My only quibble was that there were little bits of sand embedded in the seams which were a Censored to get out. I've since gone over them which loads of thin coats of Rustoleum Hardhat White, which was advertised as gloss but is more of a satin finish which is a bit annoying. Oh well, apart from not being shiny they look lovely.
Post #735775 19th Oct 2018 8:39pm
