Home > Puma (Tdci) > Today’s mystery object is?
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
As I approached my vehicle on Monday I noticed something resting behind the steering guard plate which I initially thought to be a stick.
On closer inspection I removed a strip of black neoprene rubber.
It measures 10mm x 12mm x 625 long.
I had recently (2 weeks ago) removed the top of the viscous fan blade housing to see if there was any debris inside but all was well.
I’m wondering if the rubber strip had come from there and become unattached and had dropped down.
I’ve had another look but cannot see where the rubber (if it had been attached initially) could have been located?
One of the ends is slightly pinched as though it had been clamped down and there is evidence of adhesive in places but not sticky now due to dust.
Any ideas anyone.......do you have a strip of rubber anywhere underneath your fan blade housing and if so where ?
2010 Defender 90
Cheers Thumbs Up
Post #735350 17th Oct 2018 6:21pm
ickle
strip from under the radiator?
Post #735358 17th Oct 2018 7:07pm
Zed
Cuddly toy?
Post #735372 17th Oct 2018 7:49pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Yup, I've found this hanging from the front of mine too. I've just pulled the thing out now. Presume it's not really needed.
Post #735398 17th Oct 2018 9:08pm
mk1collector
There a foam strip under the fan top cowl on top of the radiator. Ray
My build thread
Post #735420 17th Oct 2018 10:43pm
BenB8man
I'm sure mine was underneath the rad. Are there supposed to ones top and bottom?
Post #735423 17th Oct 2018 10:54pm
lonewolf
Ray.....would that be right at the front of the cover, tucked under a lip so when the fan cover is fitted it sits over the upright edge of the top of the front horizontal metalwork?
I did try it back in that location but it wasn’t exactly the same length so dismissed it.
I’d also cleaned the cover so any tell tale marks would have been wiped off.
The amazing thing is it must have been lying on the inside of the steering guard for a couple of weeks and not blown away!
Thank you for your input.
Glen
Post #735426 17th Oct 2018 10:57pm
lonewolf
Ben, I never looked under the radiator as I never removed the bottom half so there may be one down below, who knows?
Somebody on here will know though Thumbs Up
Post #735427 17th Oct 2018 11:00pm
BenB8man
It's all good, it didn't look too important. If you have one on the top though, I'm missing two of them! Laughing
Post #735430 17th Oct 2018 11:11pm
mk1collector
Glen
That’s the one, it fits somewhere around there. Ray
My build thread
Post #735431 17th Oct 2018 11:14pm
lonewolf
Neoprene put back on with double sided sticky tape in the place mentioned. Whether that’s the correct location who knows, but it does appear to be the correct length for that place Wink
Post #736363 23rd Oct 2018 5:56pm
