Home > Td5 > how to mount decat pipe?
Cedwat
France 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi,
I just ordered a decat pipe and a straight pipe to replace the central muffler for my TD5 Defender.
The straight pipe assembly seems pretty straight forward, but the decat pipe seems a little bit more complex.
I have been searching on the web for a "howto" to remove the old cat pipe and replace it with the new decat.
Does anyone know where I would find that?
Many thanks.
Post #73492 30th May 2011 6:07pm
landy andy
I don't know where you would find a vid, but is very simple, and straight forward.
You will have to remove the gearbox cross member to get it out tho.
Andy
Post #73507 30th May 2011 8:13pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
What happens come MOT time then? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #73548 31st May 2011 7:33am
Cedwat
Embarassed Embarassed Embarassed
I just realised that my 2000 doesn't have a catalizer ... Rolling Eyes
Post #73574 31st May 2011 10:55am
Grockle
nothing, it's not an MOT requirement 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #73586 31st May 2011 1:46pm
K9F
landy andy wrote:
You will have to remove the gearbox cross member to get it out tho. Andy
Yes you do! Unless you wish to take drastic action and cut the old exhaust out....the decat pipe can then be manipulated into place without unbolting the gearbox cross member. (I didn't cut mine out but I know a man that did!).
On the Puma the decat being the size of an immersion heater I needed to slightly apply pressure with a jack on the gearbox to give me the extra couple of millimetres room to facilitate the 'cat' removal. Box o' spanners and a couple of hours it should be done whatever method/approach you take. Good luck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #73607 31st May 2011 5:40pm
gambit
Did the man that cut his exhaust have any problems as a result?
I had mine changed for me, but I didn't bother to keep the CAT seeing as it wasn't / isn't an MOT requirement...
Had I realised that cutting out the old exhaust would've had a go myself...
.... probably Whistle
Post #73654 31st May 2011 9:26pm
K9F
None whatsoever, but considering the cat has quite a monetary value even as scrap I have kept mine intact. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #73711 1st Jun 2011 9:37am
chiefstoker
So, with the decat pipe how does performance compare? 2005 TD5 90 Hard Top
Post #73922 2nd Jun 2011 10:08pm
K9F
It is generally accepted that removing the cat and it's associated restristive characteristics this will allow your turbo to spool up quicker and give you more 'grunt' at lower rpm. My backbox also got canned. The difference to me was quite noticeable. Exhaust tone is notably different and with a lifetime warranty on the exhaust system I need never worry about shelling out in future.
More info here:
http://www.defender2.net/forum/topic3204-30.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #74187 4th Jun 2011 11:21am
chiefstoker
Thanks K9F Cool 2005 TD5 90 Hard Top
Post #74299 5th Jun 2011 11:08am
