![]() | Home > Off Topic > Ifor Williams tyres and LED lights |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
See what tyre profiles you can get most of, When I had the metro gta, I had to change the profile tyre to something else due to the tyre profile been no longer produced. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Regarding LEDs I wouldn't bother as they fail quicker than decent lamp units with bulbs and are more expensive in the first place.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I’m not so sure have you looked at the price of. Rubboliite lens for one now
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Not sure if there is sufficient load with LEDs to operate the indicator warning lamp on the dash?
Cheers Keith |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365 ![]() ![]() ![]() |
You will need quite £££ let's units if you want them to last.
Go on western towing or trailer tek or similar and see what rims/tyres are popular. Compass tyres always worked well for me. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Yeah but rubbolites are needed to dampen all the rattling and vibrations that the Ifors create
![]() ![]() Last edited by Romadog on 16th Oct 2018 8:16am. Edited 1 time in total |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
I got my Ifor for particularly good money... but requiring attention! It had no floor, no brakes, no factory lights, just a light board.
18 months ago I did a complete rewire using LED lamps. I chose lamps based more on dimensions/shape to fit within the factory recessed locations - they were just cheap ebay units. Can't comment on longevity beyond 18 months but currently they're still working well and that's after a particularly bad Welsh winter! With regard to the Defender indicator warning lamp; my Defender has LED lamps fitted with the adjustable relay so provided the relay is adjusted properly the warning indicator still works Will be interested to see comments on tyres. I currently have 13" fitted but am also considering changing. ![]() Click image to enlarge |
Thanks for the feedback Hank.
Yeah I bought one that needs a bit of a tidy up too, and I’m weighing up the cost of the rubbolites that need replacement vs the LED and there’s not much in it. I think the best add on for them is the rubber stick out side markers. I’m tempted to try the Maxxis Trailer tyres, they seem to get decent reviews and sticking to the 12” tyres. I’ve run Maxxis on a few cars and they’re a good quality afordable tyre. Some people knock the Ifors, but I don’t think much of the Indespension or Brian James axles especially on the car transporters. I used to have a CT177 and that was a beauty, got rid of it though as everyone else seemed to be using it more than me and everytime it came back with a new broken bit or scrape- went to use it one day and had two broken lights, a flat tyre and the winch broken and that was the end of that! ![]() The Ifors just seem to hold their value so well too, there’s some abused lemons out their for silly money though. |
Mine had rubber side markers (incandescent) fitted but they were tired so I replaced them with ebay LED equivalents with the same hole centres so were a straight swap.
Will look in to the maxxis tyres thanks. I've seen some trailers fitted with chunky tyres but that might be a bit much for my use. I would like to raise the hitch slightly so larger wheel/tyre profile would help out here. There are always those who love to talk things down but lets be fair IW are the highest regarded manufacturer and for good reason. Shame this makes them high risk theft targets! I can't say I have much experience with BW or Indy. I did borrow a BW car transporter years ago, seemed ok. I feel your pain on the lending out - the number of friends that have come out of the woodwork needing this or that shifting etc is significant! I love a good trailer, be sure to report back how you get on! |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
I have 12" maxxis on mine
![]() ![]() ![]() /www.ebay.co.uk/itm/STRONGHOLD-Hitch-Lock-for-Knott-Avonride-couplings-IFOR-WILLIAMS-TRAILERS/161809820938?epid=1739891267&hash=item25ac9ded0a:g:hbgAAOSwd0BV4hw3:rk:28:pf:0 |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
The LED lights on my trailer were £22 a pair off ebay some 4 years ago, still perfect now and it lives outside all year.
That hitch lock looks good value.
Yeah when you add up the three lights I need to replace and one bulb holder as rubbolites it’s already around £50 which made me think a bit what have i got to lose on some cheap eBay LEDs, apart from my sanity ![]() |
I found that the LEDs in each light started to fail reducing the amount of light showing.....meaning complete replacement.....found it easier to replace a bulb.
I always fit the bulbs with copper slip on metal surfaces and also make sure holder is tight on bulb.....gentle squeeze with pliers. ![]() |
dielectric grease is a better choice than neversneeze on electrics
![]() Local Ifor dealer has said he’s sold a ton of Ling long ( ![]() |
