![]() | Home > My Defender > The new workhorse - 300tdi 90 rebuild |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Great project, nice to see another one being saved!
| under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 153
Well September turned out to be a crazy month, but progress has been made none the less
Had to treat the old girl to a lot of shiny new things This was the entire amount of oil I emptied out of entire vehicle Click image to enlarge First up set of shiny new stub axles, the old set had worn due to loose wheel bearings wearing ridges in them Click image to enlarge Rebushed, new shocks and springs too |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
Ideal!
Makes me want to do another one 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Lol....Don't let me lead you astray
Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
Never a boring life when you own a Landover! Let me know if/when you need another set
I think another project might be a divorce level event 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
lol.... I'll take you up on that offer Grafty.
Acquired a bargin set of extended studs for the wolf rims Click image to enlarge On with the new discs and bearings.... Even the locknuts were knackered after countless tightening using a screwdriver instead of a socket Click image to enlarge Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Nice progress
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5376
looking good there
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Cheers Clayton & Procta
So both diffs rebuilt Click image to enlarge Calipers launched into scrap bin, pistons well and truely seized and resisted all know methods to free them off Click image to enlarge New calipers, dust shields and the back end is complete Click image to enlarge Next up front end Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
Looking good there, so much better as you can see it's loved at even this point of the build
I know this is a bit of a long shot, but what did you do with all the matting in the cab under-rover 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Without looking in the boxes Clayton I'm not sure what of it if any I kept, were you after anything specific? Cheers
So now Iv'e got my bum in gear and sorted the pics, it's time for a quick update and fast forward through the front axle
This axle was in the same delightful state of repair as the rear and so the scrap pile grows New swivels, seals, bolts, gaskets fitted and races for the swivel bearings installed Click image to enlarge Swivel housings shimmed up, and seals fitted....The stop bolt and top bracket are the right way around now for the eagle eyed amongst you Click image to enlarge Stub axles replaced as they were on a par with the rears, worn through badly adjusted wheel bearings. One had destroyed itself internally too, with nothing left of the thrust washer or needle bearing. Click image to enlarge Hub intenals renewed and fresh discs fitted Click image to enlarge Calipers, again were in same state as the rears and unsalvagable Click image to enlarge Finally back up on 4 wheels Click image to enlarge Lastly for this quick post Panhard rod, steering box and associated linkages, dampers etc fitted and a new chassis loom dragged through Click image to enlarge That's all folks, well for now anyway Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html Last edited by under_rover on 14th Oct 2018 12:10pm. Edited 1 time in total |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Just in case youve set them up and torqued them with the wrong figures, that’s not a railko bush- theyre the bearing type, Railko has the fibre washer disc
Lol NickMc.... you're quite correct, was just this old dinosaur stuck in the terminology of old
| All times are GMT |
