![]() | Home > Maintenance & Modifications > Sad Sad Day RIP Mr T-max |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Those are not the only options though. There is also Viair. Although there are mixed reviews on the smaller units of those as well.
| eddy Member Since: 05 Aug 2012 Location: Mandurah WA Posts: 12
I was at an auction yard the other day,where a few ex Australian army Land Rovers are coming up for sale.The 6x6 dual cab running an Izuzu turbo diesel was fitted with an endless air compressor,twin cylinder.I put up some pics on the Aulro forum.Expensive way to go....but it does come with the vehicle to drive it! https://www.aulro.com/afvb/military-land-r...ys-wa.html
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
For circa £26,000 if I had that amount spare I would of brought that 6x6 dual cab It looks absolutely epic.
Well the compressor fund has taken a bit of a beating after the recent headlight wiring issues so budget rules over shear ability. as much as I would love a Twin ARB It'll have to wait until a later date. The logic says buy another T-max and just carry on what I have done in the past but I gather the pressure gauge is just as inaccurate as was to begin with. but I wonder if there is a third way as after all i'm that kind of person to do it differently I Just need to find out the style ARB use as I think the T-max uses a KL or KL-F connector (It was a few years ago I got my coil extension hose made) Either that or use the ARB pump up kit and change the outlet connector on the compressor. Hmmmmm |
Yes,it went for an exorbitant amount of money.......someones long term investment?
ARB's digital tyre inflator may be the way to go.https://www.arb.com.au/air-compressors-tyre-accessories/tyre-accessories/ |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
I used to have a TMax, it was irritating to use so I fitted a pressure switch. It wasn't overly happy living under the bonnet though.
6 months ago I moved over to the twin ARB mounted under the driver's seat and it's so much better to use. The only issue I've had is that I originally plumbed the output of the ARB using 12mm OD nylon air line which couldn't take the heat and melted. I've now got some braided line (ironically Viair) which I'll use for the first section. It does get quite a bit of use (though I doubt as much as davew) and the hose only let go after a lot of tyre inflations. I'd just aired all of my tyres up from 0.8 to 2.2 bar so (12-33PSI) so it had understandably got a bit warm. One issue you need to be aware of with the TMax et al is that all the quick connect fittings they use are mounted backwards. This is to stop air leaking out of the tyre when you turn the compressor off to check the air pressure but it means that you can't use them with a traditional tyre inflator without fitting a pressure switch. The switch on the body of the compressor is just controlling an internal relay so it's easy enough to hack should you want to. If you're ever near East Anglia you're welcome to the remains of mine if you want it. |
Thanks for the info Cupboard
I don't venture near east Anglia often though. I'm going to go with the t-max then figure out the way of getting a trustworthy pressure gauge. |
