![]() | Home > Off Topic > If a basic Puma Defender is still a bit too posh... |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
http://www.topgear.com/uk/photos/james-may...?imageNo=0
Can't believe they're still being made! ![]() |
Certainly be easy to maintain, and very cheap
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Not a bad little motor - cheap, robust and simple
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Of course a basic puma is too posh, it has a dashboard and centre console instead of a shelf in which you can put a bag of mint imperials, and the engine is controlled by
Rebuilt 1996 black/white Defender 90 300 TDi |
Way to posh! Whats an electric window?
![]() A Heater? Pah! Just put a hat and gloves on! Ben Rebuilt 1996 black/white Defender 90 300 TDi |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Sounds like an ex of mine..... Not the current Mrs Monkey of course ![]() |
![]() ![]() I think I want a Niva..... ![]() |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
They aren't that posh! Leccy windows that you have to hold the button down, windscreen wipers from the stone age, gearboxes that still rattle around...ahhh.... 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
That Niva's quite impressive actually... That bad isn't it!
![]() 22900013A Same problems, but with more comforts. You know it makes sense! ![]() Rebuilt 1996 black/white Defender 90 300 TDi |
this is funny. definitely not real, but still quite cool nonetheless
&feature=player_detailpage |
Thats ace! 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
4x4 Magazine brought one of these up to Tong recently and put it to test around the off road site as part of a large test of almost every 4x4 currently available. Whilst I wasn't allowed to drive it I did watch it in action and it went brilliantly off road, largely due to it's light weight and simple mechanicals.
Not pretty but does it what it says on the tin!! Pic here..... http://www.4x4i.com/features/road-tests/35...-2011.html Bit of video on the home page too. Andy |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
The Lada looks a lot like the old Fiat 127 ... but with a suspension lift !
![]() Click image to enlarge ![]() the door handles ... the dash ... ![]() ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Struth that brings back memories. I bought a couple of Niva's back in the early / mid 80's (had Land Rovers at the same time), the first one felt like a bag of nails but the second was relatively smooth - both were pretty capable in standard form. The trim felt like recycled vacuum packaging and split and cracked if you dared so much as look at it. The transfer box mount shimming was critical IIRC. Steve.
