Home > Technical > Help - Indicators have died!
pom
Got in yesterday and nothing happens when indicators turned on either left or right. Hazards work just fine.
I looked in the manual but there doesn't seem to be a fuse for them unless im blind.
Anyone else had similar before i call out LRA ?
cheers
Pom
Post #73406 30th May 2011 9:49am
mse
I think your blind! Fuse im sure is the same as the brake circuit (shows you there is a problem there) - ill go and check, but im almost sure. This must be old defender!
Update
Fused at 31 and 21 according to the wiring diagram - but your right it doesnt show it in the manual, as they are just the hazard switch fuse...have you tried that Mike
Post #73407 30th May 2011 10:02am
pom
Brake lamps F13 no mention of indicators.
LRA on their way!
Pom
Post #73408 30th May 2011 10:07am
noworries4x4
If its a puma the indicator fuses are under the drivers seat, if they blow straight away again check the bulb holders at the rear are not full of crud and shorting out, Also under dash in other fuse box check it indicator relay has not wiggled out a bit not making contact. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #73409 30th May 2011 10:09am
mse
LRA on their way!
Pom
Just checked and updated for you - my v8 manual shows it on brake circuit - so i read the wiring diagram for you and the answer is above Mike
Post #73410 30th May 2011 10:12am
pom
31 and 21 are hazards not indicators and per my first post the hazards are working fine.
thanks anyway.
LRA are only an hour away so will see what they say and report back.
cheers
Pom
Post #73411 30th May 2011 10:15am
mse
thanks anyway.
cheers
Pom
Would you like the wiring diagram?? They say hazards but they are wired to indicators Thumbs Up
It then goes via the hazard switch to header k109 and then to the idicator Mike
Post #73412 30th May 2011 10:16am
mse
Having said that it could be anything...indicators are over-rated anyway! Mike
Post #73413 30th May 2011 10:20am
pom
im just going from the manual!!
Post #73414 30th May 2011 10:21am
mse
The sheet 2 bits show you the buld - the cut out above is the main circuit from the wiring manual Mike
Post #73418 30th May 2011 10:25am
Grockle
as I mentioned some time back, coat the bulb holder and connectors with vasaline to stop corrosion of the contacts happening Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #73423 30th May 2011 10:51am
pom
LRA are having a look as we speak. IT is a weird fault as the central locking doesnt flash the indicators but when you press the hazards they work!
Will update when its fixed.
Post #73433 30th May 2011 11:53am
pom
and the verdict - bloody water in the front indicator!
Will be taking the tip to vaseline all the bulb holders.
Big thumbs up for LRA though, 1 hour response, friendly and knew exactly what he was doing. No why cant dealers employ these guys!
Pom
Post #73435 30th May 2011 12:06pm
mse
Pom
They would make no money
Glad its sorted Mike
Post #73440 30th May 2011 12:57pm
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Pom
I have had the same issue a few weeks ago. Took it to land rover and they said the would have to strip the whole car which would take 2 days and they would be charging me £70 per hour for the electrician !!! There is alot of condensation in my lights so im wondering if this may be the problem after having so much snow laying on the car ?
Did you just dry it out and it started working properly again ?
thanks
Post #208870 6th Feb 2013 1:37pm
