![]() | Home > Wheels & Tyres > Boost or deep dish?? |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Personally, I prefer the Deep Dish to the Boost alloys. Maybe it's just that they're a bit more "curvy" against the squared off "boxiness" of the Defender.
![]() (Says me with neither on mine at the mo ![]() ![]() |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 ![]() ![]() ![]() |
Boost for me, untill I can aford some Duel Finish
![]() 10 years in a WOLF, WIMIK and Snatch and this is all I have to show! |
There is an additional consideration. IIRC and I am sure someone with more knowledge will correct me on this if it turns out I am mistaken...
The Boost alloys weight carrying specs are rated high enough for a 110, whereas the Deep-dish are not. This would obviously have insurance implications should it be decided that the wheels were not the correct spec for the vehicle. Anyway Boosts look much better... ![]() ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
Deep Dish are correct for a 110. It's the Tornados which aren't weight rated for a 110.
Tornado wheel: ![]() Click image to enlarge Deep Dish on 110: ![]() Click image to enlarge ![]() ![]() |
Thanks Martin. You are absolutely right I was thinking of the Freestyle/Tornado rims...
Of course the Deep Dish were used on the Camel Trophy 110s... and they wouldn't take risks on safety would they ![]() ![]() Do you know of a place where the specs for these wheels can be found? such as load rating etc. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Excellent! Until I read this post I didn't know my current wheels were 'deep dish'. I knew they weren't boosts, but that was as far as I'd got. Now I know - and that they are 110 rated. After 16 odd years I'd probably assumed that anyway! Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1311 ![]() ![]() |
I prefer the Boosts and have them on my 90 County Hard Top.
But Freestyle alloys are the correct spec for this vehicle - so if anybody has some of these close to East Anglia, I could be interested. Tyres not needed. |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I like the deep dish on the more retro Defenders, boosts look better with bigger tyres imho
![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 ![]() ![]() |
Learn something everyday, thought a boost was a boost, didn’t realise the 110s were different
![]() “Goes outside to see what’s on mine” |
The alloy option went over to Boosts for both 90 and 110 in around 2002 IIRC. No Puma has Tornados or Deep Dish as factory fit. The grey ones on my 90 above came off my other 90, and they were originally off a Disco 1 ES.
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Deep Dish if its a TDI Boosts if its a Td5 ![]() N. |
Hmm. My year 2000 Td5 had deep dish.
As Martin said above, the changeover was around 2002. Darren
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 824 ![]() ![]() ![]() |
In my mind (rightly or wrongly and probably the later). The deep dish seem a bit beefier. They look like there is a bit more metal in them and therefore stronger.
On the other hand I am running a set of ZU alloys so ![]() Time to get me coat..... 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
